- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI RBK50 - ISP DHCP LEASE PRESENT - INTERNET CONNECTION GOES OUT
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an RBK50, used with Spectrum in SoCal. The gist of the issue is that the Router sees that it has a DHCP lease from the ISP but there is no internet. It goes out like once a day and I have to physically power cycle the modem to get the connection back. Spectrum insists that its the router. They have come here, tested all the lines and the modem and everything checks out on their end. I have no idea why this happens.
I once just left it all night, and the connection never came back on its own either.
Power cycling the router does not fix it, has to be the modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI RBK50 - ISP DHCP LEASE PRESENT - INTERNET CONNECTION GOES OUT
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have power cycled both modem and router multiple times. When I lose connectivity I only need to power cycle the modem to get it back. Power cycling the router alone does nothing.
Firmware Version: V2.3.5.30
The modem is branded as Charter Spectrum all over but underneath it says:
EN2251
Hitron Technologies, Inc.
DOCSUS 3.1 eMTA
I googled it but nothing came up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
if thats the case the I would talk to the ISP about this:
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
- Mark as New
- Bookmark
- Subscribe
- Permalink
ISP says its not them, they checked the line at every point and they say its fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try a factory reset on the RBR and setup from scratch. Be sure to not enabled any Armor, Circle or Traffic Meter. Power OFF the ISP modem for 30 seconds as well after you reset the RBR. Walk thru the setup wizard with a wired PC and web browser.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@latemetal wrote:I have power cycled both modem and router multiple times. When I lose connectivity I only need to power cycle the modem to get it back. Power cycling the router alone does nothing.
EN2251
DOCSUS 3.1 eMTA
wow...and I thought my firmware was old
- Mark as New
- Bookmark
- Subscribe
- Permalink
Lol, yeah. Apparently the router does not notify you at all about new firmwares. I am 2.7 now. Maybe it will fix it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My satellite uses a wired backhaul. This is not a wifi issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi latemeal,
Good day!
Welcome to NETGEAR Community!
First of all, we do apologize for the inconvenience of not getting back to you immediately due to backlog. Regarding your concern, when the issue is happening, did you check the connection on your modem before you reboot or powercycle the modem? Can you still access the router's user interface when the issue happens? Did updating the firmware fix the issue?
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
@latemetal wrote:I have an RBK50, used with Spectrum in SoCal. The gist of the issue is that the Router sees that it has a DHCP lease from the ISP but there is no internet. It goes out like once a day and I have to physically power cycle the modem to get the connection back. Spectrum insists that its the router. They have come here, tested all the lines and the modem and everything checks out on their end. I have no idea why this happens.
I also have Spectrum in SoCal. Back in March there was a major problem with Orbi's losing the ability to resolve URL's into IP addresses using the Domain Name Service protocol (DNS). DNS failure results in the appearance of "no internet". While this is not likely to be your problem (a) because firmware 2.3.5.0 was not affected and (b) because restarting the router would be a temporary fix, would you be comfortable checking on whether this is DNS failure or IP failure?
i.e. attempt to ping a known internet resource, such as dns.google.com or one.one.one.one
If this fails, attempt to ping them by IP address, i.e. 8.8.8.8 and 1.1.1.1
If this also fails, then there is definitely a "loss of internet"
p.s. I have an Orbi system on firmware 2.3.5.0 that works great. (not on Spectrum)
