- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI RBR40 - no wifi broadcast
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an ORBI RBR40 with two satellites. Today, it suddenly stopped "broadcasting" a wifi signal. I used my old router and it works, so no problem with cable modem. I tried factory resetting and the power on light just stays green. I cut it on and off over and over. I unplugged it. I tried connecting my computer with an ethernet cable. Nothing works. Best Try (oops, meant Best Buy) basically told me that I could just buy another one. After all, I wanted a $500 trio of bricks. Any ideas of how else to fix the issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI RBR40 - no wifi broadcast
When factory resetting the device make sure to hold the reset button for 10+ seconds the power light should go orange. If that does not work I suggest contacting support.
http://www.netgear.com/support/contact.aspx
DarrenM
