- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
One of the Orbi satellite drop internet connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have my Orbi RBK 43 (One router and two satellites) in my apartment. Both satellites shows "Blue" color for the connection strength. However, one of my satellites (Satellite 2) drops internet signal occasionally and it will not connect to internet again. If I walk with by device to the "Satellite 1" or router, the internet will be normal again, i think it is because my device will connect to them when close to them. It proves that "satellite 2" drops internet signal. I have to restart the "Satellite 2" to get connect again. What I can do?
I suspect the location of "satellite 2" has relatively unstable signal due to the walls, but i am not expecting that the drop of internet connection of "satellite 2" cannot be resumed automatically.
I am also wondering if I can force "satellite 2" to connect to the router by 2.5 Hz signal.
Please help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: One of the Orbi satellite drop internet connection
It's probably the location of the satellite. It could also be interference. Try chaging the WIFI channel of your Orbi system.
If you are totally wireless is daisy chaning off or on?
For testing purposes can you move the satellite closer to the router, or if daisy chaining, closer to a satellite?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try swapping RBS around with the other working RBS to see if the problem follows or not.
@RoundRound wrote:I have my Orbi RBK 43 (One router and two satellites) in my apartment. Both satellites shows "Blue" color for the connection strength. However, one of my satellites (Satellite 2) drops internet signal occasionally and it will not connect to internet again. If I walk with by device to the "Satellite 1" or router, the internet will be normal again, i think it is because my device will connect to them when close to them. It proves that "satellite 2" drops internet signal. I have to restart the "Satellite 2" to get connect again. What I can do?
Please help.
