Orbi WiFi 7 RBE973
Reply
Orbi AC3000 router solid Magenta
Faxman
After a couple of year of problemless use  I have now ended up with a solid purple ring on my router and the satelites. I have one computer connect with a fixed cable to the Orbi router and this computer gets internet access. Over wifi I can barely connect to the system and I once I succeed in connecting to the wifi I can not access my network settings through the Orbi App, it can not detect the products. Wifi units have no internet access. I have rebooted the system a couple of times with the same result everytime - a solid magenta ring on the device and no internet access. Since my computer that is directly connected to the router has internet I know the problem is not with my ISP.
Any thoughts on how I can fix this?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 8
Accepted Solutions
Faxman
Re: Orbi AC3000 router solid Magenta
I had access to an extra router, did a factory reset on it and my old satelites, and then set everything up again using my old network details. Now my network works again. Not sure if I had a hardware fault, but that would be my guess.
Message 5 of 8
All Replies
Guru
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
Message 2 of 8
Faxman
Yes - I have done the 1 min shut off of both the fibermodem and the Orbi router as well as the satelites.
When it comes to firmware I can not check which version I have since I can not connect to the Orbi units with the app. I have not preformed any update over the last 6 months, but I do not know if any automatic updates could have happened since.
My modem that is connceted to the fibre is a Inteno Broadband Technoloy AB, model name XG6846
My unit is a Orbi RBR50 router.
Message 3 of 8
Guru
To find the FW version, please user a PC or laptop and connect to the RBRs web page at 192.168.1.1 to find the version.
Also your modem may have a built in router. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
Also have the ISP check signal and services up to the modem. The router is dependent upon having a good signal from the modem.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Message 4 of 8
Faxman
Message 5 of 8
Guru
Ok sounds good.
Let us know what the FW version you have loaded is.
Please mark your thread as solved so others will know.
Enjoy.
Message 6 of 8
Faxman
My firmware version is V2.7.3.22
Thanks for the input anyhow.
Message 7 of 8
Guru
Enjoy. Smiley Wink
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1615 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
