× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Orbi LBR20 Signal Being Used and Manual Testing
PMC181
Hi all,
I have an Orbi LBR20 with cable internet and LTE Failover to Verizon setup for some time now. I can't seem to find answers to these questions in the manual or in this forum.
1. How can I tell at any point in time if the unit is currently using cable internet or LTE? The app in my iPhone shows both connections, but which one is it using?
2. How can I manually test the system for failover? Is it as simple as disconnecting the ethernet cable between the cable modem and the LBR20?
3. If the failover works correctly should I still have my ethernet connections downstream of the LBR20 still working and also the WIFI from the LBR20?
I am asking these questions because we have lost our cable connection a couple of times and I'm not sure if the LBR20 switched over or not.
Thanks in advance for any input. I could not believe I could not find these answers in the manual.
pmc181
Message 1 of 3
Accepted Solutions
burrington
Star
Re: Orbi LBR20 Signal Being Used and Manual Testing
1) Advanced Tab > Internet Port window shows the current path.
2) Yes, just disconnect the ethernet cable, or power down the landline internet modem.
3) Yes, if you wired it correctly, everything will still work properly, but internet will be via cellular.
Note that it takes a couple minutes (about 3) to switch over to the cellular, and about a minute to switch back. I think this is to prevent wild switching on an intermittent connection.
Message 2 of 3
All Replies
burrington
Star
Message 2 of 3
PMC181
Thanks for the help!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1126 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
