Splnthgs1's avatar
Splnthgs1
Orbi RBR20 does not connect to internet through Draytek Vigor 130
Have just purchased RBR20 which worked patchily with BT HH6 so upgraded to Draytek Vigor 130. It is not not possible to connect to internet (BT) at all - any help you can give will be appreciated.
Stephen
  • Splnthgs1's avatar
    Splnthgs1
    Mar 09, 2019
    Thanks all.  A little late night research showed that I hadn’t entered the bet internet password into the router!  Once I had done that all works well.
  • What FW is currently loaded?
    Is the Orbi system operating in Router or AP mode?
    Modem Combo Units:
    This would be a double NAT condition which isn't recommended. Couple of options,
    1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Be sure to power OFF both Modem and Orbi. Power ON the modem after 1 minute. Power ON the Orbi after 30 seconds. Walk thru the setup wizard with a wired PC and web brower connected to orbilogin.com
    Stephen
    Stephen
    Is that this device?
    Vigor 130 ADSL/VDSL Modem
    If so, it looks like a straightforward modem, but I would check out the mode. Some modems, such as the Netgear DM200, have to be configured into modem only mode to work with a router.
    Can you connect the modem to BT without the router in place?
    If not, sort that out first. There's not much help that anyone from Netgear can give on that front.
      Splnthgs1
      • FURRYe38's avatar
        Guru
        So the Modem is bridged?
        Would be helpful if you gave feedback to the questions presented next time
        Glad it's working now.
        Enjoy. :smileywink:
