- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR50 | AC3000 goes offline repeatedly for short periods
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an Orbi RBR50 | AC3000 router that has worked fine since 2019. Beginning in February 2022 the router goes offline many times a day for several minutes (18 times yesterday). I receive notifications from my thermostats that they are not connected. If I check my router via the NG/Orbi app it shows the router offline. It usually remains offline for several minutes and all is good again. What is causing this to go offline constantly? Nothing has changed in the setup, physical or otherwise. No option for support via the Orbi app, everything is expired. Did something change in the firmware? Is this a faulty router?
Hardware Ver: RBR50
Firmware Ver: v2.7.3.22
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50 | AC3000 goes offline repeatedly for short periods
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
