- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR50 + satellite iOS disconnection issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a Orbi RBR50 router + satellite that keeps disconnecting iPhones. Fore some reasons IPads work fine. FW 2.4.5.17 iOS 12.4.1 on the phone and IPad. I’ve tried some setting for older FW read here on the forum but no change. Armor Sequrity has expired and not renewed so not in use. This is very annoying, does anyone have any ides what I can try? Thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50 + satellite iOS disconnection issue
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
