- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR50 unresponsive, but RBS50 responsive
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I'm supporting an RBR50 - RBS50 combination. The RBR50 is acting just as an AP, the router is a pfSense router/firewall. I can see the RBS50 satellite, and there are a bunch of clients connected. The RBR50 is actually working. I can see clients connected because WiFi clients are online according to the pfSense router/firewall.
However, when I try to go to http://[ip address of RBR50], it's non-responsive. In fact, in pfSense, it's suggesting that the RBR50 is offline. Is there anyway of getting access to the RBR50 to maybe reboot it? I've tried rebooting the router/firewall, and the clients on the RBR50 remains connected, and I can actually reach the clients, but I just can't get a hold of the RBR50.
Thanks in advance.
b
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50 unresponsive, but RBS50 responsive
Is the IP address of the RBR while in AP mode, the same address as seen on the firewall device?
Is the RBR using a static or dynamic IP address configuration?
@thisisbenwoo wrote:Hi,
Thanks in advance.
b
- Mark as New
- Bookmark
- Subscribe
- Permalink
The RBR50 is running the latest version of the firmware. Yes, the IP address is set correctly, because the RBR50 has a reserved DHCP address.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the version of FW?
What happens if you connect a wired PC to the back of the RBR?
Try orbilogin.com as well...
Does a ping to the RBRs IP address result in returns?
Can the Orbi app access the RBR?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Android app is showing that it is offline. I can't remember exactly which firmware it is, but I think it is V2.5.2.4. I'm remote from the Orbi, so I am limited to what I can do. I think the only direct wired connection is between an unmanaged switch and the pfSense router/firewall. All the clients connected to the RBR50 are still working. In fact, I can work on a couple of Raspberry Pi's that are connected over WiFi to the RBR50.
It's not responding to any pings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would get on site to see what the problem maybe.
Did you have connection to the RBR before?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, it just magically disappeared. I was hoping not to have to go onsite! Oh well!
