Nilla_'s avatar
Nilla_
Follower
Dec 23, 2019
Orbi RBS50 locked up
for the past several weeks I noticed my WiFi seemed a bit slow (80-90 down, normally in the 400s) so I did a reboot of my main Orbi RBS50 router. After rebooting one of my satellites lost connection and would not reconnect. I tried rebooting it with no luck and I tried pressing the sync button on it and my main router with no luck. I tried holding down the reset button with no luck. I have a solid green light above the power button on the back of the satellite, but it never changes color or goes out while I hold in the reset button and the blue or sometimes purple light on the top of the unit never turns on. I just passed my 1 year warranty and after contacting Netgear Support was told that the unit died and that I should just buy a new one. I asked if I could pay to have it repaired and was told no, I asked if I could get a discount on purchasing a new one and was told no.
Is there anything that I can do to troubleshoot this unit before I scrap it and buy something else. With netgear’s lack of customer support I will probably just go with another brand.
1 Reply
  • So do you see the back LED turn amber if you press the back reset button for 15 seconds then release? If no, then I presume the RBS is hosed. Might ask about an RMA.
    What FW is loaded on the RBR?
