Kentboyjohn's avatar
Kentboyjohn
Orbi Sattelite keeps dropping out
I am fed up with my Orbi Sattelite keep dropping connection.  I have had it in the same position for 2 years and all was perfect but the last couple of months it drops every day several times and I have to reboot it every time. It's going in the bin soon and I won't touch a Netgear product ever again
  • What Firmware is currently loaded?
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    • Kentboyjohn's avatar
      Kentboyjohn
      You ask so many questions it's almost like it will be my fault. It's been working fine for two years and now it's crap so can only be a software update that's screwed it. I paid £350 to have it work not to employ a data engineer with it.
      • Retired_Member's avatar
        Retired_Member
        So start at the beginning....."What Firmware is currently loaded?"   And while you're at it, share with us how you came about this FW?
      Kentboyjohn
      Firmware is V2.5.1.8
      Modem is a DFRAYTEK Vigor 130
      Home is a small detached house and the satellite is on the same floor and no more than 18 feet away from the router
      I HAVE TRIED ALL THE VARIOUS CHANEL SETTINGS SUGGESTED
      4 Neighbours showing + My Sky Box and HP Printer and some Google speakers/hubs
      I am beginning to pull my hair out with it.
      I have factory reset but makes no difference
