× NETGEAR would like to hear from you about specific features so we can improve your experience. To participate in this survey please click HERE.
Reply
Orbi Wired connection drops
Bib8050
Tutor
I have a C7000v2 connected to RBR50v2 with  1 satelite running wirelessly, I have two GS608 switches as well.  Everything on the wired network is Cat6 and my trunk lines are Cat7 from the modem to RBR and RBR to the switches.
I am having constant issues where the wired devices drop from the network, the orbi still sees them in the app but there is no wired internet connection.  The wireless will continue working as usual during this time so I have internet going from the C7000 to the RBR but no wired output from the RBR.
I have removed the GS608 switches and ran direct cat7 to my desktop and continue to have the problem
I have the C7000 setup in bridge mode and I have disabled the wifi on it and I have the RBR in APmode.
This problem is always corrected if the modem and rbk are powered off and then back on.
Please help or the orbi is going back into the box and being returned to the store.
The RBR is running Firmware v2.3.5.30
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router, GS608v2|Desktop Gigabit Switch, RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 6
Accepted Solutions
Guru
Re: Orbi Wired connection drops
If you have the C7000 in bridge mode then you need to set the RBR to router mode.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router MK83+ (Router Mode) | and RBK853 (Router Mode) | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MR6150, R7000, R7800, R7960P, R8000, R8500, R9000, RAXE500, RAX50, XR450, XR1000, EX7500/EX7700
Message 2 of 6
All Replies
Guru
Message 2 of 6
Bib8050
Tutor
I am resetting that now. I thought I read somewhere that it needed to be in AP mode. its been running off and on half working for two weeks in AP mode where it works fine and then drops... Just put it into router mode and will see what happens.
Message 3 of 6
Guru
AP mode if you leave the C modem in router mode. If the modem is in modem only mode, then the RBR needs to be in router mode. The network needs a DHCP server enabled either on the modem or on the RBR to work right.
Message 4 of 6
Bib8050
Tutor
I have reset the RBR into router mode, not sure where I read it needed to be in AP mode.  super irritating, also realized the stock cable that came with the RBR was cat 5 so I swapped that as well.  everything appears to be working, I have been pulling my hair out for two weeks trying to figure out why wifi is working fine and wired is dropping, freezing etc constantly.  Thank you for the help!!
Message 5 of 6
Guru
I would bet the problem was misconfiguration and the cable. CAT6 is recommended.
Please mark our thread as solved so others will know.
Enjoy. Smiley Wink
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2147 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
