- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi and Ring products issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi and Ring products issues
I borrowed an Amplifi HD set up and can confirm no issues with Ring for it. My cams all loaded within 3sec. Orbi just does not want to do Live View with the my battery powered Ring devices, the plug in ones seem fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Having similar issues since I installed an Orbi router & satellite. Except my stick up cam stopped sending notifications & cloud recording motion. I could still live view but that was it.
I have a FIOS wireless gateway & re-enabled the 2.4 wifi on it (had disabled it & the 5.0 on the Fios so erverything ran on the Orbi system)... lo-n-behold, the Ring stick up cam now sends and records motion. Just adding my 2 cents, hoping someone knows of a workaround. My 2.4 signal sucks out where I wish to mount the stick up cams. Which was mainly my reason for wanting to go with the Orbi system!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem Combo Units will be a casue of double NAT and cause problems with another router such as the Orbi router connected it it:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem leaving it in router mode and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nothing to do with double NAT. The ring devices simply disconnect from the netgears after awhile. I had put mine on an old AP plugged into my Orbi sat to get it to stay online. Based the research I did at the time this is pretty common issue with Ring and Netgear routers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It probably does if you have a modem with a router built in and install the Orbi in router mode. This does cause a couble NAT condition and would inhibit some devices to connect with there services. Since you put yours in to AP mode, seems to confirm this with your configuration.
Hope this will help the other poster though.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
good lord what a horrible and glaring problem. once again, Netgear making its users the beta testers. I was having this problem but my Ring Pro is wired into my doorbell transformer. I think it has nothing to do with battery vs wired.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
well mine is wired and it does the same thing as battery ones (black screen on live view)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
no, one wall (obviously) and then 11 ft to a satellite.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
as others have stated with trying other Wifi systems Ring works fine with them so I'm not going to convienently throw Ring under the bus here if they work with other systems just fine. There wouldn't be a thread 7 pages long if Netgear wasnt partly to blame.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The fault is a bit on both sides. I have 6 Ring cams, chime pro, Ring alarm and another dozen devices related to the alarm too. I'm a Ring subscribers so I've replaced all my 6 Ring cams (including the doorbell) due to various issues under their extended warranty program. So Ring also does have a lot of issues. As 2019 arrives, I'm waiting to see which Ring cams I need to replace this year. LOL.
Anyways, it's basically this. You take one product with some issues from one vendor, and take another product with some issues from another vendor. Put them together, voila! We get the 7 pages of the mess! I have spent lots of time with Ring and lots of time with Netgear to make my system work. Fortunately, I'm an engineer, so I'm used to stuff not working together. And yup, they should work cuz you paid for it, but anything WIFI based will always have issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Using 2 wired video doorbells.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Before I returned my Orbi system, I determined that live view was always a problem when connected to the satellite. When connected to the router node, it would be fine.
Anyhow I'm back to a standard single router system and my ring doorbell works perfectly without any tweaks or hoop jumping so I'm a happy camper.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Most of the issues are with the Mfr of these IoT devices. There mostly supporting 2.4Ghz only and there setup software only supports 2.4Ghz during the setup process. They fail to relized that most homes not days have 5Ghz supporting mobile devices and in the last two years, WiFi Router Mfrs have deployed these all in one single SSID MESH wifi systesm. Most home devices are a mix of 2.4ghz and 5Ghz. Most mobile devices automatically connect to the 5Ghz while the 2.4Ghz only supporting devices connect to the other radio. The Mfrs have failed to develop there setup software to better allow and uses setup devices on 5Ghz since both frequencies are on the same network. This causes problems during the setup process and leads to false problems places with Orbi. These IoT mfrs needs to step up and ensure there products work with all these various kinds of MESH networks. They do work and work well and they are not going away anytime soon. IoT mfrs just needs to make a small tweak and then there software would probably work well. Shouldn't be that hard.
@james7777 wrote:
I think it's a bit funny all the hoops you guys are having to jump through in order to get Ring doorbell to work with an Orbi system. Wayyy too much fiddling around required, that's for sure.
- Mark as New
- Bookmark
- Subscribe
- Permalink
As I mentionned a year ago now, moving to a different mesh manufacturer fixed all my issues. For the past year, no fiddling or anything like that, it just works, as it should be expected.
My new mesh has one unique SSID for router, satellite and 2.4 and 5. All Ring equipment connect to the 2.4 with no confusion.
At the end, is it a mix of issues between Orbi and Ring, making it not to work at its best, and such issue do not show on what I have? No idea, but as mentioned earlier, manufacturers should verify that their equipment works on mesh network, OR mention an incompatibility if the problem is not on their side (similar: I saw a manufacturer of wmart plugs specifying which mesh network were not compatible).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Agreed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks that worked for me.
I have added a Ring Spotlight Cam Battery (already got a Ring Flood Light Cam and Ring Pro) and was having a problem with only Live View everything else worked fine with the Spotlight Cam.
I change my Orbi Router settings for the Spotlight to a static IP and now live view is working everytime.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks that also seems to have worked for me.
I have added a Ring Spotlight Cam Battery, Ring Doorbell 2, my Ring Chimes and Ring Chime Pro (although now have no need for the Chime Pro network). I too was having a problem with only Live View, everything else seemed to work fine with the Spotlight Cam and Ring Doorbell 2 although they had some latency issues.
I change my Orbi Router settings for all my Ring devices to having a reserved IP address and now live view is working everytime.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just a quick update - I thought that changing my Orbi Router settings for all my Ring devices to having a reserved IP address had resolved the problem, but it appears not and I am completely back to where I was previously with live view timing out!
Frustrating as it is, the motion video capture works just fine, but as a previous contributor noted, what's the point of having a camera if you can't 'drop in' to check on things!!
Any other suggestions would be most welcom 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just a quick update since my last post Live View has stop working on my Battery Spotlight Cam.
The Static IP Config only worked for a few days. Motion detection works fine and has also worked.
My Ring Door Pro and Floodlight Cam work fine with Live View.
I am waiting on a Chime Pro to see if that sorts it out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has anyone tried turning off NAT security like I did? No problems since I did that. Please try it and let me know. Most of you are using batteries but mine is hard wired so I’m curious.
