× Our systems will undergo a planned maintenance on Sunday, May 19, 2024, between 12:00 AM and 02:00 AM Pacific Time. During the maintenance window, you will not be able to log in to your MyNETGEAR account (including apps), renew a subscription, or register a product. However, you will still be able to use guest checkout to purchase a new product or subscription service. Updates will be posted to Status.NETGEAR.com. We apologize for any inconvenience this may cause.
Orbi WiFi 7 RBE973
Reply
Orbi frequently loses Internet connection
lbeck02
Guide
I bought the RBK53S-100NAS system a few weeks ago to replace a Netgear WNDR3700/Amped Wireless1000 system to increase my wireless range.  Also, my previous system would lose Internet OCCASIONALLY - maybe every few months.  I could always get Internet back by resetting my modem and router.  But since my system was maybe 6 years old, I decided to upgrade to the Orbi.
I really like the app and the Internet info provided by the Orbi, but I now lose Internet connection MUCH more frequently.  Maybe several times a day and almost always when I move my android smart phone or tablet (Samsung S2) out of my network area.  I'm always able to regain connectivity by rebooting the devices, but this is really annoying.  I have noticed Orbi satellite 1 backhaul status is "poor" but I don't know what that means or how to correct it.
Practically all of my devices are wired to the base or one of the 2 sattellites, but my phone , laptop, and tablet are of course wireless.
Overall my experience with the Netgear system is more satisfying and I'll return the Orbi unless I can get more stable Internet connectivity.   But after resetting passwords on alll my Orbi-connected devices and because I like the Orbi user interface, I'm hoping to save my Orbi installation.
What can I do to help you to help me?
Message 1 of 12
CrimpOn
Guru
Re: Orbi frequently loses Internet connection
Just to clarify, it is the Orbi (and everything connected to it) that loses Internet?
Or, is it the device that moved that loses internet?
Message 2 of 12
lbeck02
Guide
No.  The Orbi stays connected.
It's only my wireless connections that lose connections (I think).  I'm still setting things up but my desktop always stays connected and it's on the primary (not satellite) orbi.  My main problem is with wireless connections to my phone, notebook, and laptop.  I'm also having problems with a wired AV receiver and just this evening with my smart TV (Samsung 65") but these problems may be due to botched setup.  My TV is back but still working on the receiver.
Message 3 of 12
Akgq
Initiate
I have the same issue, I’m on the latest update. All connected devices via wire stay online. However wireless devices drop every 5-10 mins. When I checked the status. Wired connection time is up for 10 hours while wireless connection both 5g and 2.4 won’t stay up for 5 mins
Message 4 of 12
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
This is a nuisance because you then have to reconfigure the device all over again.
You can backup your settings before you reset and restore them later. But that may just bring back the fault. Then again, at least you will know if the reset fixed the problem.
The factory reset is more a "witchcraft" move than a technically informed solution, but it does seem to fix problems, especially on the wifi front.
Message 5 of 12
Akgq
Initiate
Yes I did a factory reset yesterday, still the same issue
Message 6 of 12
kmorimt
Initiate
Having the same issue. Phone and other mainly 5g devices drop and report failure to configure IP. Everything will be fine again for 10 to 15 minutes and then stop working. Everything was working just fine for weeks after the last firmware update. I did try giving it a static Channel this am and will see what happens.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 7 of 12
Guru
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 8 of 12
SBG66
Same here. Had Orbi for only 2 weeks and getting intermitent drop outs. Everything is still connected including the router to the internet. Searched and searched and cannot find any solutions. Getting worried I've bought a dud! Any advice welcome.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 9 of 12
Guru
Message 10 of 12
SBG66
Ok.
Vigin superhub 3 - Modem only mode.
Orbi in Router mode
Have just disabled Daisy.
House is around 2500 sq ft.  1930s semi with thick brick walls.
Will give your other suggestions a go.
Thanks
Message 11 of 12
Guru
Ok, let us know.
Some building materials will impact wifi signals. Smiley Frustrated
@SBG66 wrote:
Ok.
Orbi in Router mode
Thanks
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 6972 views
  • 5 kudos
  • 7 in conversation
Announcements
Orbi WiFi 7
