- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi loosing part of the network NOT Internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have 2 satellite and 1 Orbi router set up. All parts of the network could access Internet and no issues as far as I could tell. However intermittently I would not be able to ping one of the satellite and all the thing that connects to that satellite from the rest of the network. If I walk close enough to satellite and force my phone over then I could.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi loosing part of the network NOT Internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hm, you'd think if you lost LAN on the satellite, you'd lose the internet, too; the Orbi satellites use a type of LAN (the backhaul) to get internet.
Maybe expected question: have you checked your backhaul? Is it steady and strong? If you don't know how, check my instructions here. Technically, both satellites should be dropping, though, so you might not have the same issue.
You're on v1.10.1.2, right? Did you try re-syncing the 'bad' satellite? Does it come up blue for signal? (you've probably done these, but I just want to check).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, right. 😞
True! Maybe there are 'degrees' of being affected. I wonder if sometimes people are close enough that the backhaul drops are covered up because it instantly switches to the strong router SSID for those few seconds: so the connection is never interrupted.
And maybe it's more noticeable in some of our home architecture: I'm often too far from the router so my laptop (which is a 1x1 AC antenna, too) is primarily connecting to the satellite. I use Skype a lot for work and that keeps me on edge when I lose WiFi.
IMO, I want to say it's related to the same issue. Or maybe someone else is experiencing this and can chime in. I don't know if you're still in the 90-day free phone call time period, but maybe start a ticket there. Maybe Netgear knows some weird bug we don't. At least they'll maybe be able to set you up with a replacement.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
