- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi plus Asus RT-N66U DHCP
- Mark as New
- Bookmark
- Subscribe
- Permalink
Am my better off just using the Orbi alone, or use it with the router. I have all my dhcp stuff...reservations and ranges set up on the asus. Should I just start fresh with only the Orbi...or can I use both and retain all my settings with the ASUS as DHCP....and of so...what steps do use, in order to use them both ?
Thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi plus Asus RT-N66U DHCP
Yes, If you have the Asus all set up as your main router, just turn OFF it's wifi radios and configure the Orbi system for AP mode:
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
You can use the Asus routers DMZ for the Orbi then configure the Orbi for router mode, this will be two routers on the same line and problems could happen. If the system works for you in AP Mode, use that mode for your needs.
@mswells wrote:
I am currently using an ASUS rt-n66u router.
Thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My two cents: had RT68u, switched to Orbi router and two satellites over a year ago, saw the major difference, sold Asus at yard sale. Asus has a cooler looking interface though.
- Mark as New
- Bookmark
- Subscribe
- Permalink
There are performance differences between single, dual, and quad core CPUs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So the DMZ needs to be set on the ASUS router, when setting the Orbi as an AP....or just to
use both the Orbi and ASUS as routers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
