Orbi WiFi 7 RBE973
Reply
Orbi rbr50 inconsistent internet unless I use device vpn
Sjeric
Follower
I have had the Orbi system for over a year. Recently internet from all my devices have been very spotty. The only time it works is when one of the decide on the network has a von. If the device uses a von then everything works great for that specific device. Why is this happening?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Orbi rbr50 inconsistent internet unless I use device vpn
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Has a factory reset and setup from scratch been performed since last FW update? Power OFF The ISP modem for 30 seconds then back on then walk thru the setup wizard after doing a factory reset?
"If the device uses a von then everything works great for that specific device." Whats "a von"?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 422 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
