jonneym
Oct 08, 2017Follower
Orbi satellite issues following 2.0.0.74 update
Following 2.0.0.74 update the strength of satellite and router connection reduced impacting speeds off satellite to connected devices. Additionally blue or orange light remains on constantly. No issues previously. Fixed by reverting to previous firmware for a few days until devices re-update to 2.0.0.74 then same problem. Help
1 Reply
Sort By
- howiedubTutorDo you have Daisy Chain Topology enabled under Advanced Setup > Wireless Settings? If so, see if disabling that helps. I noticed the same thing and when I disabled that, my satellite speeds went back up.
