- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi - set satellite to wireless backhaul only (aka - disable it as an access point)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is there a way to set an Orbi satellite to only use wireless backhaul and prevent any device from accessing the network via the thing? Trying to force a device that is marginally closer to the satellite to use the router because the device tends to randomly flip between them causing disruptions and packet loss.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi - set satellite to wireless backhaul only (aka - disable it as an access point)
Basically - I want to use the satellite as a bridge.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, you can't disable the satellites broadcast capability.
A couple things you can try.
1. move the satellite. maybe its to close to the router. It needs to be at least 30 feet between router/satellite
2. you can turn down the broadcast power. If the router/satellites are to close, sometimes turning down the broadcast power helps devices roam better.
