Orbi WiFi 7 RBE973
Reply
OrbiLogin requiring contant authentication
studdawg
For the last couple of months, the web login from my desktop is useless.  I can login ok to the orbi but it then constantly asks to reauthenticate.  Most times it accepts the credentials but sometimes it doesn't and I have to give up.  It's made it so it is unusable.  Anyone else having this problem?
Message 1 of 7
CrimpOn
Guru
Re: OrbiLogin requiring contant authentication
My experience is there are certain screens which pop up the user/password screen every five minutes or so (and other screens that do not).  The "Attached Devices" screen is the one that annoys me the most.  So, yes, I feel your pain.
Message 2 of 7
Guru
What firmware version are you on? (please don't say the latest)
I know one of the versions had significant issues with this.
If you're on the most current, try factory resetting it and reinstalling.
Message 3 of 7
studdawg
yes, i believe it's the latest.  It's an RBR50.  Firmware is v2.3.5.30.  And i've also noticed a drop in range as well associated with this firmware.  So resetting will fix the firmware?
Message 4 of 7
Guru
Maybe. Its worth a shot.
Have you tried any other web browsers to see if its an issue with your pc/browser?
Message 5 of 7
studdawg
I have.  I tried with both firefox and chrome and had the same issues.
Message 6 of 7
Guru
Be sure to clear out ALL browser caches before entering into the routers web page. Clear caches then exit the browser then re-open the browser then log in.
Has a factory reset and setup from scratch been performed since last update?
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1117 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
