- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R50 something
- Mark as New
- Bookmark
- Subscribe
- Permalink
R50 something
how you get it to stop giving you the incessant not found screen or asking me to login to every site i go to. this is some ridiculous cluster**bleep** of a product. (and one that has security added on to the product) i've never experienced anything like it and for 94 download for $600 is the worst decision i've ever made.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R50 something
You could return the product? If you don't like it, you don't have to keep it.
There have been a number of posts about problems such as this, which have been resolved after providing information about the specific modem the Orbi is connected to and the specific devices which are having problems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R50 something
The ISP modem and the way you connect the Orbi units together can affect the way Orbi functions.
Please provide more details about your setup so we can help you.
We are all here users of Orbi units and we have seen different issues, small and big, which we help each other to solve or find a workaround for!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R50 something
It was connected to Verizon Fios Modem and now it's connected to Comcast modem as of yesterday. It has Netgear Armor on it. Same problem 404 page and then asks you to login. Sometimes it will let you look at page and sometimes not. Happening to everyone that tries to use the network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R50 something
It doesn't seem to matter which modem it's connected to or which device you connect to. all the laptops and phones in the house are having a problem. Mac or PC, Android or iPhone.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R50 something
With 1GB service is 144 Mbps really the best speed this system can do? Makes more sense just to plug into the wall.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R50 something
Please open a Command Prompt on any computer attached to Orbi and type:
> tracert 8.8.8.8 (or traceroute 8.8.8.8 if you're using a Mac computer)
1. If you see two private IP addresses listed in the first two hops then you have double NAT. Please check the model of your ISP modem and if you have a manual for it.
2. If you see only one private address and the second hop shows a public address, then you’re all good and we need then to troubleshoot further to find the root cause of the issue,
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R50 something
I can return the 2nd batch to Costco, but I'm still stuck with the first batch. Then what? This stuff is supposed to be plug and play. The instructions say so. Plug it in and it works.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R50 something
@ekhalil wrote:
One of the reasons that can cause such strange -unjustifiable- issue is having double NAT in your network.
One thing to keep in mind, if people such as this, are having problems with what appears to be an issue of TWO routers on the same network, I doubt they understand the term 'NAT'
Simple language sometimes is better.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R50 something
> tracert 8.8.8.8 (or traceroute 8.8.8.8 if you're using a Mac computer) and post the results so we can help you further.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R50 something
Last login: Tue Aug 6 14:00:46 on console
(base) HQSML-1649490:~ krenne952$ traceroute 8.8.8.8
traceroute to 8.8.8.8 (8.8.8.8), 64 hops max, 52 byte packets
1 172.16.0.1 (172.16.0.1) 6.451 ms 4.074 ms 4.287 ms
2 10.0.0.1 (10.0.0.1) 10.554 ms 10.372 ms 6.333 ms
3 96.120.77.57 (96.120.77.57) 14.775 ms 18.392 ms 16.072 ms
4 68.85.193.237 (68.85.193.237) 17.113 ms 19.605 ms 15.283 ms
5 162.151.181.9 (162.151.181.9) 24.362 ms 19.723 ms 18.138 ms
6 be-201-ar03.ivyland.pa.panjde.comcast.net (96.108.181.21) 22.542 ms 19.000 ms 20.283 ms
7 69.241.64.98 (69.241.64.98) 23.519 ms 25.396 ms 21.297 ms
8 * * *
9 dns.google (8.8.8.8) 24.093 ms 22.305 ms 21.342 ms
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R50 something
Comcast was installed yesterday. I do not have a manual for the modem or know how to do anything to it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R50 something
@ihateorbi wrote:.....
Thank you for this.
The above shows very clearly that you have two routers in your network. Orbi has the IP address range 172.16.0.x and the Comcast has the 10.0.0.x which is causing you the issues you're seeing.
You have two options:
- Change Comcast to pass-through or DMZ mode.
- Change Orbi to AP Mode. You can change Orbi to AP Mode in the web GUI (orbilogin.com) under >> ADVANCED >> Advanced Setup >> Router / AP Mode
