- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK13 speeds
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBK13 speeds
What speeds are you seeing with Orbi RBK13?
I have devices connecting at 866Mbps but transfer speeds are around the 200Mbps mark.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK13 speeds
After numerous reset and reflashes as instructed by support they have just told me I should return it to where I bought it!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK13 speeds
Please don't leave us hanging. They said, "return it" because (a) this particular unit is defective, or (b) the RBR13 doesn't have the processing power to handle 866mb?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK13 speeds
I have asked support that question in a different way.....will a replacement set resolve the issue? awaiting an answer.
I did run a performace test that has left me a little concerned on the processing power side.
ran iperf3 between a laptop to a desktop over ethernet cable and got 900+ Mbps - good, as to be expected for 1G connections.
put the orbi router effectively between the laptop and desktop via the ethernet cables using the second ethernet port on the orbi router and only saw 600Mbps. repeated the tests numerous times and got consistent results.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK13 speeds
Lost the will to live with support!
Getting absolutely nowhere with them.
I do have a certain sympathy with the front line guys are they are clearly not being backed up by the higher levels of support/engineering when they do not have the information to answer the questions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
