Orbi WiFi 7 RBE973
Reply
RBK43 Ethernet Backhaul not working
Bokkers
I am using a pretty simple setup. Cat6 cable from the port right of the WAN port on the RBR40 directly into left port on RBS40. Cable works fine, tested directly into laptop without wifi and had full speed available. If I look in the setup (browser), backhaul status is poor and utilizing 5G instead of cable/wired.
Firmware version 2.3.5.30. Daisy chain off (tried with on as well, same result).
Any ideas?
Model: RBS40|Orbi AC2200 Tri-band WiFi Add-on Satellite
Message 1 of 12
Guru
Re: RBK43 Ethernet Backhaul not working
The yellow WAN port needs to be connected to your ISP modem/ONT. One of the white LAN ports on the RBR should be connected to the back of the RBS.
Message 2 of 12
Bokkers
Satelite connected to one of the white ports indeed and firmware version 2.3.5.30.
I have also followed this:
  1. Switch off the Satellite
  2. Go to Attached Devices in the web GUI and click on the "Disconnect" button beside the Satellite in questions
  3. Turn on the Satellite and use a paper clip to factory reset the Satellite
  4. When the Satellite is up after factory reset, press the Sync button on the Satellite (while the Ethernet cable to the Router is connected) and then on the Router
  5. When the Satellite is added it should behave correctly.
Same result...
Message 3 of 12
Guru
Disconnect the ethernet cable from the RBS.
Factory reset the RBS, then Turn OFF the RBS.
Select Remove from RBRs web page for the RBS. It should say disconnected. Apply the change and reboot the RBR.
After the RBR is bakc to ready. Power ON the RBS and re-sync it to the RBR WIRELESSLY first. Ensure it connects and appears in the RBRs web page. Top LED should turn BLUE.
After the top LED on the RBS turns OFF, connect the LAN cable between the RBR and RBS. The top ring on the RBS should turn ON, PINK I think. Then should turn BLUE.
Check the status on the RBRs web page.
Message 4 of 12
Bokkers
So I did all of that, and was refreshing the device list in the browser at the end. I had a wired connection (and blue light) for about 5 seconds, after which it went back to a poor  5ghz connection again. I thought putting a wire in would make my life easier (dropped connections due to RBS too far away from the RBR), but I am still stuck at the same place....
Any other ideas?
Message 5 of 12
Guru
Try a factory reset on the RBR and RBS. Set up the RBR with the setup wizard. Add the RBS wirelessly first, then connect eithernet.
If this still fails, the system maybe faulty and needs replaced/RMAd.
Message 6 of 12
Bokkers
So had a moment this morning with an empty house, so I would not disturb the kids with their internet being down. I did a full factory reset and setup via the wizard. The end result is the same.
How can something so simple (according to Netgear their documentation you just plug it in and it works) be so complex? This was working a year ago, when I originally purchased it I used an old cat5 cable, I had connection wired, but the cable was slower vs wireless. The product is just over a year old, cannot get in touch with Netgear without paying 89 dollars for a half year of support for something that should just work.
Thanks for your help so far, I hope you or other members of the community have some other suggestions, otherwise it will be an expensive excercise, buying a new set all together...
Message 7 of 12
Guru
So after setting up wireless RBS first, they connected correct, then plugging in the RBS via ethernet did not show a wired connection?
"old cat5 cable" Lets try a new CAT6 cable. Cat5 is old and doesn't support 1000Mbps connection rates very well.
Message 8 of 12
Bokkers
The old cat5 was in the previous situation a year ago, I am now running it on a brand new Cat6 sFTP cable, which works perfectly fine connected to the laptop.
I have tried in a various ways, but none are working. Also they way you describe in your last post, but no success. Still my poor 5G connection.
Message 9 of 12
Guru
Wondering if your RBR or RBS is faulty. Something  you might contact NG support about.
@Blanca_O
Message 10 of 12
Bokkers
If you know a way to get in touch with them. Or is that via @Blanca_O ?
Thanks so far for you kind help @FURRYe38
Message 11 of 12
Guru
Yes, send a PM.
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 1667 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
