- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR20 Satelite
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBR20 Satelite
TIA
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR20 Satelite
@Timnooner wrote:
No hand shake between the 2. Do I have to make a crossover cable or something?
What were you expecting? You just plug the satellite into the router and take it from there. No special cable needed.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
You might like to search there for messages related to your issue.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR20 Satelite
try a different cable. it wouldn't be the first one that "tested good" on a cable tester but wasn't of high enough quality ends/cable to actually pass a signal.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR20 Satelite
Hello @Timnooner ,
Welcome to the NETGEAR Community!
I understand that you are having issues with syncing your RBR20 to your RBS20. Please try to factory reset your RBR20 and your RBS20 to resolve this issue. This issue may also be caused by a faulty cable as @plemans suggested. Swapping your existing ethernet cable may be needed if the factory reset is unsuccessful.
Please keep us updated on the progress of this issue!
Best,
Kevin
Community Team
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
