ChristyReams's avatar
ChristyReams
RBR20 and PlayStation 4
We have had our PlayStation 4 connected to this routed since we got the router in August. Today, it has stopped being able to connect. It shows it can establish the network, the IP address, but fails when it tries to make the internet connection. When I log into the Orbi app, I can see the PlayStation connected and it shows it's getting a good signal, but the PlayStation 4 says it has no internet connection. Recommendations from PlayStation is to restart the modem, then try the router if that doesn't work. Have done both of those and have had no change. I have also called our ISP and they did some things and say we are getting a great signal at the modem and they didn't see anything on their end. When I look at the connection details on the PlayStation, everything looks good including the IP address, default gateway, etc (by good, I mean matching the configuration on my laptop) until it gets to the NAT Type setting and then it is showing "Failed". Everything I keep finding says it is an issue with the router, but I don't know how to fix it. Any ideas? All other devices in the household are connecting fine.
  • 1. What modem is the orbi connected to?
    2. What firmware is on the orbi?
    3. Is the playstation the only device having issues?
    4. Is it connecting over wireless or wired?
    • ChristyReams's avatar
      ChristyReams
      The modem is a Netgear CMD31T modem. Firmware on the Orbi claims it is up to date when I check for updates. It is running v2.3.5.26. the PlayStation is the only thing that seems to be having an issue. It is trying to connect wirelessly.
      • plemans's avatar
        Guru
        A couple things you can try.
        1. factory reset the orbi and redo the setup.
        2. Try hardwiring in the playstation to see if it'll work.
        3. try downgrading the firmware on the orbi. Maybe there's an issue with the firmware you on if it was working prior and nothing else changed.
        4. Try setting a static address for the playstation
