Orbi WiFi 7 RBE973
Reply
RBR20 problems after updating firmware to 2.3.5.30
elseesea
Follower
Just used the built-in updater to update my RBR20 and 2 satellites, both RBS20, to firmware 2.3.5.30.
Now, I have two problems:
First, in Advanced \ Setup \ Internet Setup, I cannot manually set the DNS servers manually unless I also use static IP address. I like to manually set the DNS servers to Google's - 8.8.8.8 and 8.8.4.4. When I press "Use These DNS Servers" radio button, nothing happens - the "Get Automatically from ISP" radio button remains selected.
Second, in Advanced \ Advanced Setup \ Traffic Meter, the traffic volume shows zero in all fields.
Anyone else having the same issues with RBR20 and firmware 2.3.5.30?
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 3
Guru
Re: RBR20 problems after updating firmware to 2.3.5.30
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Has a factory reset and setup from scratch been performed since last FW update? Please try this...
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
Did you have Circle or Armor enabled?
Besure to disable any of these if you had them enabled. Don't enable them when you do a factory reset.
Message 2 of 3
Retired_Member
Not applicable
What's a built in updater?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 466 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
