× Our systems will undergo a planned maintenance on Sunday, May 19, 2024, between 12:00 AM and 02:00 AM Pacific Time. During the maintenance window, you will not be able to log in to your MyNETGEAR account (including apps), renew a subscription, or register a product. However, you will still be able to use guest checkout to purchase a new product or subscription service. Updates will be posted to Status.NETGEAR.com. We apologize for any inconvenience this may cause.
Orbi WiFi 7 RBE973
Reply
RBR40 Orbi wired devices not connecting suddenly
Tomj1231
Follower
After 18 months my RBR40 wired devices are no longer working - One port goes to switch to rest of the house.
ISP thought it was the cable modem so I replaced (ARRIS Surfboard - Compatible with Suddenlink).
Firmware is updated ( V2.3.2.58) - Rebooted several times (2 satellites not updated and working correctly)
No other updates - which wouldn't have been updated if the problem didn't exist first
Wireless devices are working correctly - 20+ devices
Connected multiple devices using multiple ports/cables
Checked Access Control - set to "Allow all new devices to connect"
Auto DHCP - printer has a static address
Nothing else fancy - no port forwarding - just for home use
Any ideas as to why this would happen all of a sudden?
Message 1 of 3
CrimpOn
Guru
Re: RBR40 Orbi wired devices not connecting suddenly
Did this happen soon after the firmware updated?
There are three ethernet LAN ports on the RBR40.  Are all three affected?
Has the switch been eliminated as the cause?  (i.e. take something that was connected to through the switch and connect it directly to the RBR port?
You mentioned "reset", but not "factory reset", correct?
Message 2 of 3
Guru
What is the Mfr and model# of the ethernet switch in the configuration.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 773 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
