× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RBR50 + RBS x 3
Ash-jhb
Follower
RBR50 + RBS x 3
i have manually updated my RBS50 x(1 of 3)  satellites to the latest f/w (V2.7.5.4). when i ticked the 3 boxes -  it only updated 1 satellite. I did not see it at the time and proceeded to update the router, which updated fine to V2.7.5.4. Later I saw that only 1 satellite (and the router) was updated and the other 2 satellites were not. As I had read that the satellites must NOT be updated after the router is - how can I rectify this to have the other 2 satellites to the latest version as they are still on V2.7.4.24? what will happen if I now manually update the RBS50 x 2?
Message 1 of 2
CrimpOn
Guru
Re: RBR50 + RBS x 3
Most of the discussion about the sequence of updating satellite/router is in terms of the newer AX series of products.  The key is whether you can access the web interface of the satellites that the not get updated.  If you can learn their IP address from the Attached Devices page and open a web browser to that IP address, then you can probably use the satellite menu Firmware Update.
Message 2 of 2
Discussion stats
  • 1 reply
  • 155 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
