- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 dropping packets
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a RBR50 updated to latest firmware (2.5.0.38). Prior to installing this firmware version, everything was working fine. After installing this firmware, my Orbi is now randomly not responding to any network requests, sometimes for a few seconds, sometimes for a few minutes. This is the only Orbi device on the network; I have no other routers or APs (but I do have some "dumb" switches connected in a star topology).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 dropping packets
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@milklksubstance wrote:I have a RBR50 updated to latest firmware (2.5.0.38). Prior to installing this firmware version, everything was working fine.
This should tell you something.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you seeing lost packets with a wired PC connected to the RBR?
How about checking for loss of packets directly with a wired PC behind the modem?
I supposed you can go back to prior working version of FW...
@milklksubstance wrote:I have a RBR50 updated to latest firmware (2.5.0.38). Prior to installing this firmware version, everything was working fine. After installing this firmware, my Orbi is now randomly not responding to any network requests, sometimes for a few seconds, sometimes for a few minutes. This is the only Orbi device on the network; I have no other routers or APs (but I do have some "dumb" switches connected in a star topology).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Makes no difference on the modem....."Prior to installing this firmware version, everything was working fine."......
- Mark as New
- Bookmark
- Subscribe
- Permalink
Upon further review, the problem only happens on wireless. Wired devices work fine, Speedtest from Orbi works fine.
When the wireless is "working", packets are still being dropped. Problem occurs regardless of channel, on both the 5 GHz and 2.4 GHz bands.
I would love to go back to .30. How do I do that?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@milklksubstance wrote:Upon further review, the problem only happens on wireless. Wired devices work fine, Speedtest from Orbi works fine.
Go to the download page, enter your gear and see if there is an eariler version available.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This was probably overkill, but I went back to 2.2.1.212, did a factory reset on that firmware, upgraded to 2.3.0.32, changed all my settings to where I wanted them one by one while checking wireless speed at every step (it dropped each time!), then upgraded directly to 2.5.0.38. I do not experience the long connection drops I used to, but the wireless does still drop for about a couple seconds from time to time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have a RBS or is this just the RBR only?
Is Beamforming and MIMO(MIMO may or maynot be needed) and WMM enabled. Under Advanced Tab/Advanced Settings/Wireless Settings
Is 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
@milklksubstance wrote:This was probably overkill, but I went back to 2.2.1.212, did a factory reset on that firmware, upgraded to 2.3.0.32, changed all my settings to where I wanted them one by one while checking wireless speed at every step (it dropped each time!), then upgraded directly to 2.5.0.38. I do not experience the long connection drops I used to, but the wireless does still drop for about a couple seconds from time to time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:What is the size of your home? Sq Ft?
Any Wifi Neighbors near by? If so, how many?Is Beamforming and MIMO(MIMO may or maynot be needed) and WMM enabled. Under Advanced Tab/Advanced Settings/Wireless Settings
Please stop
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad to hear it's better!
Bummer to hear that you spent so much time on it.
Also bummer to hear that wireless still drops.
The last week has been quite maddening for my wife and I. Like many other community members posting in the last week, we went from a flawless pre-2.5.0.38 experience to constant connection dropping and slowness. About 12 hours ago I finally did the downgrade to v2.3.5.30. First the Satellite ... then waited to see if that by itself made a difference. Nope. Still dropping completely off the network. So I went ahead and did the RBR as well.
Since then I'm back to the way things have been for years -- i.e., my laptop hasn't dropped off the wifi a single time.
@netgear, get your **bleep** together.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having the same "blackouts" after upgrading to the latest firmware. It only happens on wifi and seems completely random.
I will reverse to an older version this afternoon. Hopfully this issue will be fixed in the near future in a new firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@SkywalkerPD wrote:I'm having the same "blackouts" after upgrading to the latest firmware. It only happens on wifi and seems completely random.
and stop doing manual firmware updates
- Mark as New
- Bookmark
- Subscribe
- Permalink
Okay, went back to firmware 2.3.1.60, and everything appears to be normal.
The house I am in is an 1100 sq ft split-level. I am only running the RBR50 on this setup, no RBS. (The RBS that came in the RBK I purchased was moved to join another RBK setup somewhere else.)
I am on manual channel 11 for 2.4GHz and channel 48 for 5GHz. Plenty of neighboring WiFi nearby; 11 is the cleanest option on 2.4 (I haven't checked 5GHz). MU-MIMO and Beamforming are off, WMM and 20/40 Coexistence are on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Next time try a factory reset and setup from scratch after FW is updated. Does work for others.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So where you still seeing problems after resetting and downgrading and upgrading as you mentioned earlier?
@milklksubstance wrote:Okay, went back to firmware 2.3.1.60, and everything appears to be normal.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
