- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 factory reset itself 2.5.1.8
- Mark as New
- Bookmark
- Subscribe
- Permalink
Curious if anyone has had their Orbi RBR50 running Router Firmware Version V2.5.1.8 just reset itself back to factory defaults?
Things got real slow for a while, I restarted the router and when it came back it was factory reset. Odd?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 factory reset itself 2.5.1.8
A long while ago on a different FW version once. Possible problem it encounted after you updated which caused this. I would probably ensure the system is working and setup again by doing a factory reset and setup from scratch. Once setup, be sure to do a back up configuration to file for safe keeping. Saves time if a reset is needed.
@ScottWay wrote:Curious if anyone has had their Orbi RBR50 running Router Firmware Version V2.5.1.8 just reset itself back to factory defaults?
- Mark as New
- Bookmark
- Subscribe
- Permalink
There are known issues with 2.5.1.8
Your best bet is to revert/roll your FW back to the last stable version and stop updating manually.
- Mark as New
- Bookmark
- Subscribe
- Permalink
In a previous community thread I was advised to move up to this as it is the most stable version. I guess I am happy to be on whatever is stable, but what version exactly might that be?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I haven't seen any reset issues with v2.5.1.8 on mine. Again, I factory reset and setup from scratch then save off a new backup configuration to file. I and others have reported stable operation with this version. Use what you feel works best for you though.
@ScottWay wrote:In a previous community thread I was advised to move up to this as it is the most stable version. I guess I am happy to be on whatever is stable, but what version exactly might that be?
- Mark as New
- Bookmark
- Subscribe
- Permalink
In the world of evolving FW, the best practice is IF your system is working, leave it alone. When you need a FW, NG will push it, no action on your part. Simple.
