- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 - rebooting daily after internet via wifi drops
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 - rebooting daily after internet via wifi drops
@BoilerPlate
Hey Boliler_Flake
You not the forum police you anywhere near qualified to be, let alone be posting in the forums or givein out information. Everytime someone posts helpful information you dump and spew pointless duplicated false ane invalid infomation. You badger and troll anyone trying to be helpful to others that are looking for help. Don't let anyone talk about there eperiences in a good way but for you is ok to. Your a complete waste of time and air to anyone in this forum. You must have a sad life to come here an dump on anyone giving help. The communiity is not yours to dump in. Go somewhere else. Stop playing the victim when your completely the instegator. You bring this all to your self.
NetGear, Please ban this user one and for all!!! Stop this once and for all for community sake!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@KoodGarma wrote:
@Doug6392 wrote:
Over 48 hours now (well on the way to 72, actually.) Fingers crossed, but the NTP fix seems to have done the trick.🤞What is the "NTP fix"? Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
@vajim wrote:
@KoodGarma wrote:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Fix is here:
@KoodGarma wrote:
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks! So just to be clear, the "fix" is to turn off Traffic Meter correct?
Do I need to do anything to do anything under NTP Settings or anything else?
- Mark as New
- Bookmark
- Subscribe
- Permalink
it appears to be a multiple errors to correct
The NTP fix is:
F) Modify NTP Settings:
1-Uncheck the "Automatically adjust for daylight savings time"
2-Change your timezone "east" one hour to accommodate turning off the auto DST.
3-This step is probably optional: Change the NTP server to 1.pool.ntp.org
The traffic meter is another part of the overal problem. If you have it checked, uncheck it
- Mark as New
- Bookmark
- Subscribe
- Permalink
THANKS - THE FIX IS ON!!!
Done - Unchecked ☐ Traffic Meter
Done - Unchecked ☐ Automatically adjust for daylight savings time
Done - Set preferred NTP server to 1.pool.ntp.org
Fingers and toes crossed this fixes things until Netgear fixes this in the next firmware update or something.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@KoodGarma wrote:THANKS - THE FIX IS ON!!!
good luck....I would use the word 'fix' around here carefully. It might mean something.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Very frustrating, to say the least.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have been reading posts:
- NTP to right timezone
- Auto adjust for Daylight savings time unchecked
- Preferred NTP server set to time.nist.gov
Also manually reset RBR50 (running in AP mode -- so no traffic meter to turn off). And manually reset both RBS50 (also running 2.7.2.104).
- Turned everything off 90+ seconds
- Turned Comcast router on first and waited for full connection and then restarted Orbis starting with main unit
Any other ideas ...
- Did notice Dynamic DNS is off but that's factory standard????
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do both wired and wireless devices not get internet when this happens?
WiFi on the modem router fully turned off?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Turn OFF the RBS and test the RBR alone. Does it exhibit problems?
Many features are disabled on Orbi when in AP mode.
@Bart1968 wrote:
Dropping internet after (2.7.2.104) firmware.
Any other ideas ...
- Mark as New
- Bookmark
- Subscribe
- Permalink
2 satellites are more than 30 feet away in different directions from RBR
I did notice with Auto adjust for daylight savings unchecked that I needed to go timezone +1 to get proper time.
I no longer have anything wired connected from back of RBR but prior experience was both wireless lost internet connectivity AND anything wired directly to back of RBR
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
When this happens, does the top ring LED turn on at all? Pink maybe?
What happens with DST enabled and set to correct time zone?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have had to restart RBR50 2x. No longer getting pink LEDs at top -. No lights at all for a while and will eventually turn Pink. From iOS device using native wifi sees SSID but says no internet connection. If restart RBR50, get internet connection for a while.
NTP settings Mountain Time with automatically adjust for daylight savings time on. Preferred NTP time.google.com
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the mfr and model# of the isp modem or host router the RBR is connected too in AP mode?
Seems the maybe the RBR is not getting signal from the host router which is indicated by the PINK led on top.
Ensure you have a good quality LAN cable in between the RBR and host router. CAT6 is recommended.
Try the following NTP server:
Uncheck Automatically adjust for daylight savings time
Try the RBR in router mode and set the DMZ on the host router up for the IP address the RBR gets from the host router.
Has a factory reset been performed since last update?
@Bart1968 wrote:
So turned off power to both RBSs
- Mark as New
- Bookmark
- Subscribe
- Permalink
factory reset = lost passwords
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Got pissed because this thing worked flawlessly for the last 6 months in exact same configuration with no change in modem, cable, or drop in my house -- only firmware update
- Went and bought RBR853 thinking it was hardware or firmware issue. Followed instructions and setup to similar configuration with latest firmware to same results. Less drops in router mode (every hour) vs AP mode (every 20 minutes)
- However, was having RBR connect through unmanaged gigabit switch. When moved cable directly to available port on back of cable modem have been up and running all day
- Weird and had thought of a bad switch so I had already replaced the switch with a brand new one however both tp-link. Comcast modem is a Technicolor CGM4331COM hardware rev 2
- So same cable, same location worked 6 months through switch but clearly doesn't now with either the old or new switch. Any chance it's a firmware and switch issue as my workstation and many other devices are on that switch and work fine?
- And looking for advice, will I see material benefit from the RBR850 with 2 satellites over the RBR50 with 2 satellites? Or should I save the $1000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Only firmware update....where have we heard these words before?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try a different brand switch like NG? NG GS-105/108v4, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems. Keep the RBR directly connected to the modem. Use a switch connected after the RBR or connect the switch behind the modem and don't connect the RBR to the switch. Connect other devices to the switch.
@Bart1968 wrote:
Think I made progress:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any thoughts on:
