Orbi WiFi 7 RBE973
Reply
RBR50v2 Dropping Connection
joe43wv
For the last week my RBR50v2 keeps dropping internet for no known reason. I have one satellite connected and the signal strength is strong. I've read through the forums and it appears this is a known issue with this model. It is running the current firmware. I did notice in one post where they mentioned trying to telnet into the router to change some settings. I went to the debug page but did not see where to enable telnet. Any thoughts on what I can adjust to make it stable?
Message 1 of 19
Guru
Re: RBR50v2 Dropping Connection
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
Please review the Recommendations under this main post page to see if there is any solutions do what your seeing as well. I see a few that are checked as resolved. No telnet needed.
Message 2 of 19
joe43wv
UPDATE: The Satellite is about 45' away from the base station, shows Good 5Ghz Strength on the dashboard. I've tried all of the settings you recommended and the issue has gotten worse. Are there any other solutions to try before contacting support for a replacement unit?
Message 3 of 19
Guru
Is the top ring on the RBR turning on when this happens? if so, what color is it?
Do both wired and wireless devices loose connection?
Message 4 of 19
joe43wv
I turned off the auto channels and it actually made the issue worse. I'm going to perform a factory reset to see if that resolves the issue. Will update with results.
Message 5 of 19
Guru
OK. Please give feedback to the question presented. Helps us out.
Message 6 of 19
CrimpOn
Guru
The latest firmware version, V2.7.3.22, removed enabling telnet from the debug page.  There is a Python hack to enable telnet, but I am unaware of anything that could be done with telnet to affect this sort of problem.
Can you provide a little more description of what is happening?  Such as:
  • Did this begin when the router firmware was updated?
    (most users do not check constantly for which firmware is running, so you may not have been aware when it updated)
  • How often does this interruption happen?
  • Does it "fix itself" after a certain length of time?
    (how long?), or
  • Is the only way to regain internet connection to  reboot the router?
  • Does this interrupt both wired and WiFi connections?
  • Does the WiFi signal continue to function, but devices report "no internet"?
  • Have you attempted to determine whether internet is "totally gone", or the problem is that DNS queries are failing?
    (open a command window and then try to 'ping' a web site first by its URL and then by its actual IP address, such as
    ping ford.com  and, if that fails ping 136.2.49.37
One troubleshooting tactic often employed  is to manually load a previous firmware version on the Orbi router.  Firmware V2.7.3.22 frustrates this practice because the router will automatically update to V2.7.3.22 again
Message 7 of 19
joe43wv
The factory reset and the settings adjustment did not resolve the issue. The internet stayed on for approximately 30 minutes and then goes back out. It does it MULTIPLE times a day. The wireless and hard wired stops working completely. The wifi completely goes away and then comes back, the hardwired can't even ping the router. The only way to get the issue resolved is by rebooting the router and satellite. It is currently running the most current firmware, but it started a couple of weeks before the latest firmware was installed.
Message 8 of 19
Guru
Wondering this would be of any help:
https://community.netgear.com/t5/Orbi/Missing-Connected-Devices/m-p/2142349/highlight/true#M126110
Message 9 of 19
joe43wv
After contacting Netgear support, they said since it wasn't a hardware issue, that I would have to pay $89.99 for premium support. I passed and just loaded the mentioned firmware. I'll report back my findings.
Message 10 of 19
Guru
Message 11 of 19
joe43wv
Update: Everything has been running smooth except the issue reared it's ugly head again this afternoon.
Message 12 of 19
Guru
Message 13 of 19
joe43wv
I've tried two different modems with two different ISP. One Arris modem on Suddenlink Cable and one Netgear modem on Frontier DSL. The oval ring on the satellite turns amber, the oval ring on the main router doesn't change color, just dark, however the power light on the back is still green. Both wired and wireless devices lose connection. The wireless SSID disappears and the hard wired connections won't even receive DHCP addresses. I've tried both auto and manual settings before and nothing changes.
Message 14 of 19
Guru
Can you verify that the RBR has same FW version loaded as the RBR?
Message 15 of 19
joe43wv
Yes, both running the same version of firmware.
Message 16 of 19
Guru
Can you temporarily move the RBS to same room or near the RBR and see if the top ring turn amber or blue then off? 10-15 feet should work here.
Message 17 of 19
joe43wv
RBS stays Magenta because when the RBR goes "offline", the RBR stops broadcasting the wireless signal and doesn't even hand out DHCP addresses when hardwired.
Message 18 of 19
Guru
Have you tried manually re-loading v104 on the RBS and RBR with a wired PC and after the FW has loaded on units are back to ready, factory reset and setup from scratch. I would re-sync the RBS the after it's connected, turn it OFF and just work with the RBR.
Possible your RBR is faulty...
Message 19 of 19
Top Contributors
Discussion stats
  • 18 replies
  • 1922 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
