- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBS10 Firmware corrupted
- Mark as New
- Bookmark
- Subscribe
- Permalink
Experienced an internet outage from my provider recently which lasted about an hour. After everything came back I realized one of my RBS10 satellites had a flashing Red led on front panel. My research says that means corrupted firmware. I did some troubleshooting and noticed the problem RBS10 has firmware version behind the RBR10 and the other RBS10. My hypothesis is that a firmware update was in place on that satellite when the internet outage occurred which has bricked the satellite. I tried factory reset with paper clip thinking if I could get it back to factory setting I could add it back to the RBR10 and then update the firmware. Held paperclip in for over 30 seconds twice and no change at all in leds. Since it is the satellite and not the router, the tftp solution to transfer the firmware file I ran across does not seem to be an option.
Does anyone have an idea how to fix this or is there an option to just replace the satellite by just buying a new satellite without having to get the entire kit?
Thanks for any help...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS10 Firmware corrupted
they do make replacement satellites you can buy.
If you're within warranty, you could open a support case to RMA it
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you... I am well out of warranty but maybe I can find out how to purchase one. I got my setup during a Black Friday sale so the price was definitely worth it. It is such a shame that the design of this thing allows firmware update to brick you with no real way to reset to factory.
