Magixians
Aug 21, 2023Tutor
RBS50 and RBR50v2 together?
Hi
I have an RBK50v2 set up and running and want to extend my coverage by adding an RBK50 set that I was given.
I have already re-programmed the RBR50 to an RBS50.
Only question is if there willl be any problem running an RBS50 satellite with an RBR50v2 router?
Sort By
Should work as long as FW on RBS is same version as RBR.
Ok, good.
Does the RBR50v2 and RBR50 use exactly the same FW?
I noticed the RBR50 had a USB port the RBR50v2 does not have.
Does the RBS50v2 and RBS50 use exactly the same FW?
Thanks
