- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Rbk50 system duplicate ips
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a rbk50 with 2 ethernet backhauled satellites. About once a month a device cannot connect to the internet such as a firestick or phone. After doing an ip scan of the network and comparing to the assigned device list in orbi two devices are fighting for the same ip address. The only way to correct is the power off the router and satellites for a few minutes then power them all back on. Any ideas on why this is happening?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Rbk50 system duplicate ips
Is one of the devices listed in the LAN Setup table and the other not?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Seem to be both wifi. I have ip reservations also but that range is not in the dhcp scope.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, the typical practice is to set aside a range of IP addresses to use for certain devices (i.e. "reserve" or "assign" to these devices based on MAC address) and set the DHCP range of IP addresses so that there is no overlap.
These two devices, then, are not in the LAN Setup table for assigned IP address, but are both somehow trying to use an IP address from the DHCP range, correct?
- Mark as New
- Bookmark
- Subscribe
- Permalink
They are not any of the reserved ip's . The are out of the dhcp allocation and can be different devices.
I do run the parental controls also.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What tool is being used to scan the LAN? (just curious)
Does the Orbi Attached Devices page include both devices with the same IP address?
This sort of thing has been reported when there is a rogue DHCP server on the network. (some device that includes a DHCP capability that the user had not realized was there and had not intended to activate).
The problem does not resolve itself if those two devices are powered off and then restarted one at a time?
- Mark as New
- Bookmark
- Subscribe
- Permalink
First of all Thank you for the help. I use advanced ip scanner from a windows hard wired desktop. Yes it does resolved when I power off the devices but sometimes it is hard to tell exactly which ones are having the issues. One of them will just not have internet access.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That is entirely understandable. Routers, switches, and even computers have ARP tables that contain the hardware MAC address which corresponds to specific IP addresses on the IP subnet. (IPs on different subnets always go to the 'gateway' to be delivered.)
The next time this happens, it would be interesting to compare whow the IP scanner report compares with the Attached Devices page.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you. I will scan again when it happens.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Are the RBS Ethernet connected at the RBR or is there a LAN switch in between the RBR and RBS? If there is, brand and model please.
Thanks
