Orbi WiFi 7 RBE973
Reply
Renaming RBS 20 satellite
tgarvey
Tutor
I recently installed an RBK 44 system.  I've been able to rename the RBR 40 router, but when I do the same process on the RBS 20 satellites the new name appears in the Network Map for a few seconds and then reverts to the old name, i.e, "Orbi Satellite-1."  I'm on V2.1.4.16.  Any suggestions?
Model: RBK44| Orbi AC2200 WiFi System
Message 1 of 6
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: Renaming RBS 20 satellite
Are you renaming them from the attached devices page or are you logging into each satellite and renaming them?
DarrenM
Message 4 of 6
All Replies
Guru
Message 2 of 6
tgarvey
Tutor
Sorry, but I don't see any content in your response.  Anything you can offer would be appreciated.
Message 3 of 6
DarrenM
DarrenM
Message 4 of 6
tgarvey
Tutor
I was trying to do it using the iOS app, going to the Network Map and then clicking on each satellite.  Based on your question I logged in to orbilogin.com and succeeded.  Thank you!
Now, not to be greedy, but I have another question:  One on my three satellites is connected to the router via another satellite rather than directly, even though the two satellies are about equadistant from the router.  Is there a way to force a satellite to connect directly to the router and, if so, would it be wise to do so?
Thanks,
Tom
Message 5 of 6
DarrenM
If you disable daisy chaining it will force the satellites to connect to the router.
DarrenM
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3229 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
