- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Satellite blinking white will not reset
- Mark as New
- Bookmark
- Subscribe
- Permalink
My 2nd satellite worked for a few days, but now it constantly blinks white. The router and 1st satellite are fine. My overall WiFi is great. Only the satellite is malfunctioning. I have held down the reset button with a paper clip for varying lengths of time. I have tried the 30-30-30 reset and it still blinks white, but the power led cycles red when I do that. I have unplugged it for 5-10 minutes, plugged it back in, and it still blinks white. Any recommendations would be appreciated!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Satellite blinking white will not reset
Pulsing white. Your Orbi router and satellite are applying a configuration or updating their firmware.
Since that is unlikely for so long of a time, and if you cannot reset it there is a chance that it is bricked. Did the power possibly go out on it while it was applying firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks's for your response. It's unlikely that it lost power during a firmware update, but I guess it's possible. I have not had the satellite very long so I will try to get it swapped out.
Thanks again!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ha Ha, now having this issue myself after having done a config restore.
Showing one satellite connected - but I can see the other one on the network if I go to its IP.
This is just crazy that this is happening after my support period of 90 days is done and now I have no recourse except to troubleshoot this myself. This is just crazy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
How big is your house?
A factory reset on the 2nd Satellite should kick it into reboot mode with default settings and the LED should start to blink white. If it doesn't, then this Satellite could be faulty.
@jquest2wrote:
Hmm. Any updates? I just bought this system today and I hooked up one satellite and router. Then I went a upgraded the firmware. Everyone worked fine. I then decided to add the 2nd satellite, however, all it does is just blink white. Did I mess it up by only configuring 1 satellite rather than both at setup? Help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My house is about 3500 square feet but the walls are solid concrete. Now I see the power light blinking red 😞
- Mark as New
- Bookmark
- Subscribe
- Permalink
You could test the other Satellites Power supply with the 2nd one to see if it could be a power supply issue.
I would ask for an RMA for the 2nd unit.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I appreciate the assistance. If I can't figutre it out in the next 15 min, I'm taking this back to Costco and exchanging it. Just bought the dag gone thing today 😕
- Mark as New
- Bookmark
- Subscribe
- Permalink
Great, now the light is steady green with the same power adapter. But still blinking white. I'm heading off to dinner so I've give it 15 minutes when I get back.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hope the new one works if you get it.
Good Luck.
@jquest2wrote:I appreciate the assistance. If I can't figutre it out in the next 15 min, I'm taking this back to Costco and exchanging it. Just bought the dag gone thing today 😕
- Mark as New
- Bookmark
- Subscribe
- Permalink
