- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Satellite
- Mark as New
- Bookmark
- Subscribe
- Permalink
Satellite
Im 12 steps away from my Obie and its Satellite and they can not see each other??????
Any thoughts before I return this expensive waste of money?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Satellite
Orbi and satallite sat next to each other and still dont see each other.....
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Satellite
@andyp2021 wrote:Orbi and satallite sat next to each other and still dont see each other.....
This usually means your satellite was not paired successfully. Reset the satellite and try pairing again.
Also how far is your satellite away from the Orbi router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Satellite
Was FW on the RBR recently updated?
What FW Version is currently loaded?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Satellite
Is this a NG system or something from an ISP like Verizon? NG doesn't have a V2.5.1.1 version available.
Have you been able to get the RBS to sync at all?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Satellite
sorry the Firmware version is - 2.5.1.16
I have got the Orbi working along with the satellite but it only works when the WiFi on the SuperHub is switched ON. If I switch it off then the Orbi does not work, it shows full signal strength but I have no internet signal and the Satellite can not be found...When I switch the WiFi back on (modem mode only off) then I get a signal from the Orbi and also the satillite is picked up??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Satellite
I may have figured it out, - Ill give it a go tomorrow... a friend told me that if I put the Superhub into Modem only mode only one connection will work and I already have the Tivo box connected...... so Im guessing if I pull that out and connect it to the Orbi, and only the Orbi connected to the Superhub that should do it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
