- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Should I enable daisy chain?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the RBK50 and 1 satelite. Should I enable daisy chain? From everything I have seen it is only used if you have 2 satelites. I am experiencing some issues where the router slows down and has to be rebooted to fix. I have the most recent firmware and have already tried a reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Should I enable daisy chain?
Daisy Chain is not needed if you only have one satellite. It's better to have it disabled in this case.
If you have issues with slow speeds -and you're sure the issue is in Orbi and not and ISP issue- then please check the following:
- Radio channels used: please select fixed 2.4 and 5 GHz channels that are not or least used by your surrounding. Please make a wifi scan and see which channels are being used by your neighbors and select different channels if possible.
- What wired devices do you have connected to Orbi?
- Do you see the slow internet both in wired and wireless devices? Both with devices connected to the router as well as to the satellite?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can't find the Netgear wifi Analyzer app for IOS. Can you help me out please?
I have the ORBI app but that does not analyze surrounding WIFI networks to look at interference...
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's NetGear WiFi Analytics on my Galaxy Tab S2.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It appears as WiFi Analytics on my Samsung with the NG "N" in the app icon.
@Placesandspaces wrote:
I think it is actually called Netgear Analytics. You can access it through the Google Playstore on Android devices. I don’t think it is available through IOS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know if the app helps you with your channelization.
