- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Strange issues with Orbi RBR50 apps and websites
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi there,
I've had this router for about a year and it's been working fine, but I've recently started running into some really strange issues.
When using my mobile phone connected to WiFi, I can't access certain websites and some apps just don't work - specifically, all Google searches, Facebook, Instagram, and a few others. These websites work fine on all computers connected to the same WiFi network. These apps/websites work on other WiFi networks with the same phone with no issues. I have also tried connecting other mobile phones (both iPhone and Android) to my network and all experience the same issues.
I have the router connected to the router provided by my ISP that's set to bridge mode. I'm using the Orbi RBR50 router with one satellie connected and both are on firmware 2.3.5.30 .
Any help troubleshooting this would be hugely appreciated.
Thanks in advance!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Strange issues with Orbi RBR50 apps and websites
Will you please be able to download an app on the phone that can do "Trace Route" and do a trace route on the device to 8.8.8.8 and paste the results of the first 2-3 hubs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
@jerrremy wrote:Hi there,
Thanks in advance!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same strange issue with my RBR50 which is only in AP mode with my Verizon Fios Quantum Gateway router. FB, Instagram don't work, and then do when I turn off Wifi. I'm also having the solid Purple Ring on my router and can't login...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you set up a reserved IP address on the FIOS router for the RBR?
Is the RBR connected to the FIO router using the WAN port on the RBR?
Ensure the RBR is in AP mode.
Swap LAN cables between the FIOS router and RBR.
@dkkruse wrote:I have the same strange issue with my RBR50 which is only in AP mode with my Verizon Fios Quantum Gateway router. FB, Instagram don't work, and then do when I turn off Wifi. I'm also having the solid Purple Ring on my router and can't login...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello! Thanks for responding! Attached is a screenshot from my phone. Hopefully this is what you're looking for!
@ekhalil wrote:Will you please be able to download an app on the phone that can do "Trace Route" and do a trace route on the device to 8.8.8.8 and paste the results of the first 2-3 hubs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello! Thanks for responding. The modem is an Actiontec T3200M, relabelled as a Telus modem (I'm in Calgary, Alberta, Canada). Link below:
https://www.actiontec.com/products/wifi-routers-gateways/vdsl/t3200m/
I set it to bridge mode and all wifi signals are turned off, but maybe there are additional settings I need to change. Any ideas?
Thanks again!
@FURRYe38 wrote:What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
Thanks in advance!
- Mark as New
- Bookmark
- Subscribe
- Permalink
If the modem is bridged, then you should be good here.
Does the problems happen both with wired and wireless devices?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
The problems seem to happen only with mobile devices. My PC and laptop have zero issues and are both on the WiFi network.
Home is 2000 sqft above grade, 1000 sqft finished basement. The Orbi router is in the basement, sitting up towards the ceiling in the furnace room. The satellite is on the next floor dirctly above. Is that too close for the satellite?
I've tried all of the different settings you've described on the Orbi router and the same issues persist. I haven't done a factory reset since doing a firmware update, though. Is this recommended?
@FURRYe38 wrote:If the modem is bridged, then you should be good here.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Has a factory reset and setup from scratch been performed since last FW update?
- Mark as New
- Bookmark
- Subscribe
- Permalink
here's your problem...2.3.5.30
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks! What do I do with this information?
@Retired_Member wrote:here's your problem...2.3.5.30
- Mark as New
- Bookmark
- Subscribe
- Permalink
v30 is NOT the problem, the problem is that the Orbi router is in the basement where it really needs to be on the main floor. Basements are not good for wifi. Others are having good operation with v30.
https://community.netgear.com/t5/Orbi/New-Firmware-2-3-5-30/m-p/1813247/highlight/true#M73127
Same for my system. ZERO issues. Main RBR is on 2nd story while RBS is in my basement. Works wired or wireless.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I appreciate your suggestions but I'm not sure they apply to my situation. Perhaps my descripton of my problem isn't clear. I am not having any signal issues of any kind. The WiFi signal is very strong in every last corner of my house. I can run an internet speed test from anywhere and it comes back at full speed. I don't think the router being in the basement is the issue because my computers don't have the same issues with these particular websites that my mobile phones are having.
My issue: When using my mobile phone connected to WiFi, I can't access certain websites and some apps just don't work - specifically, all Google searches, Facebook, Instagram, and a few others. These websites work fine on all computers connected to the same WiFi network. These apps/websites work on other WiFi networks with the same phone with no issues. I have also tried connecting other mobile phones (both iPhone and Android) to my network and all experience the same issues. I have the router connected to the router provided by my ISP that's set to bridge mode. I'm using the Orbi RBR50 router with one satellie connected and both are on firmware 2.3.5.30 .
- Mark as New
- Bookmark
- Subscribe
- Permalink
@jerrremy wrote:.......
What DNS settings do you have in Orbi?
If set to get autmatically from ISP, can you please test to change to manual DNS and try 8.8.8.8 and 8.8.4.4 instead, and see if this will make any difference.
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes Please try DNS changes as suggested to see if this helps resolve some of our problems. Possible that your ISP DNS could be giving these strange issues.
@jerrremy wrote:I appreciate your suggestions but I'm not sure they apply to my situation. Perhaps my descripton of my problem isn't clear. I am not having any signal issues of any kind. The WiFi signal is very strong in every last corner of my house. I can run an internet speed test from anywhere and it comes back at full speed. I don't think the router being in the basement is the issue because my computers don't have the same issues with these particular websites that my mobile phones are having.
