- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Virgin Media Hub3 and Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Virgin Media Hub3 and Orbi
Thanks for this. I recently upgraded my Virgin Hub 3.0 from the original 3.0 version when it died on me due to hardware failure and the latest firmware upgrade for this rebadged Arris box renders Modem Mode when combined with Orbi a no-go. I have had to leave the wifi on the Hub to ensure Internet is accessible. I will probably convert Orbi to an AP. Other than having one extra Wifi access point I have all the functionality of the previous infrastructure, but please be wary of so-called upgrades to software etc as in this case they had a material impact on the Virgin SH3 and Orbi combination.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you configure the Orbi for AP mode, then you can disable the wifi on the HUB. This is recommended as it can cause interferences with the Orbi wifi system and having other wifi signals in close range.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Although bear in mind if you get an internet problem and your hub reboots you'll lose your wifi network and therefore local access, if you have your Orbi in AP mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recently purchased an HP Envy printer but I couldn’t use it as an AirPrint printer until I switched the Orbi Satellite off. The printer was treating it like a second network. Now the AirPrint works beautifully but the Orbi Satellite is banished to my garage. Money wasted.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I mean.. sacrificing coverage around the house and garden so you can once a month print something off your phone seems harsh? Just move nearer the AP with the printer and then print - then they will be on the same AP no?
Maybe raise a ticket on HP too as really it should just work?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Disable the Airprint on the HP printer and test the Orbi again...Orbi should work well if set up right.
@andrewjboswell wrote:
Adding to my previous reply about configuring Orbi with Virgin Hub by resetting both boxes, I just found out the Virgin hub is in modem mode, so wifi is off from that box.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I bought the HP printer so I could use AirPrint. My point is that it doesn’t work with Orbi Satellite. Disabling Airprint isn’t an option.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
Where was the printer in relation to distance from the router and satellite. If the printer if broadcasing its own wifi, this would cause interference with the Orbi Wifi. What channels is the printer using? Channels would need to be far and separate from the Orbis Wifi.
You should contact HP about this and see if they have any information regarding there printer working with the Orbi.
What channels are you using on the Orbi? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Disabling the wifi on the printer is only to see if it helps with the Orbi Wifi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your thoughtful reply.
I have no problem with the Orbi satellite other than it prevents AirPrint from working. Apart from that it works fine.
I was just posting here to help anyone else faced with the same issue.
Thanks,
Andrew
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not sure if any of these would be helpful:
- Mark as New
- Bookmark
- Subscribe
- Permalink
It has taken me a few months but I now seem to have got my Orbi system working well with the Virgin Hub 3.0. It took me so long because there are so many conflicting opinions on the Internet and none of them worked for me so I went back to basics:
Here's what I did:
1 Unplugged all ethernet cables from Virgin Hub and plugged in only the Orbi main hub, to the bottom port (port 1). [The other ports didn't work. One of the experts said to use the top port on the hub but that didn't work.]
2. Used a paperclip to reset the Virgin Hub, leaving the Orbi connected
3. Used a paperclip to reset the Orbi, then used the Orbi App on iPhone to configure it. The troubleshooting wizard popped up and fixed the internet connection. [For a while the Orbi app still said I had no internet connection but in fact I did.]
4. When the app told me to, I plugged in the Orbi satellite and set it up.5. I intended to set the Virgin hub to modem mode but I couldn't browse to the Hub through the Orbi wi-fi connection, so I left Virgin in router mode, but without connecting to its wi-fi.
6. Connected the virgin media system via the Orbi wi-fi. Don't connect it or anything else to the Virgin ethernet ports, apart from the Orbi main hub.
7. Connected my Hive by ethernet to the Orbi main hub
8. Connected my Echos via the Orbi wi-fi
9. To connect Sonos I had to use an Ethernet connection from my Sonos Playbar to my Orbi main hub.
Now I am getting 200Mbps wifi everywhere in my house, and down to the bottom of my garden, so I am happy at last! As I sit here typing this my Orbi app reports the internet speed is 393Mbps download and 21 Mbps upload.
Long story short - the reset wizards fixed it for me.
Good luck everyone!
That worked - thanks so much, Andrew!
- « Previous
- 1
- 2
- Next »
