- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wi-Fi faster than ethernet
- Mark as New
- Bookmark
- Subscribe
- Permalink
My ISP is Spectrum in Los Angeles. Previously, my CBR40 worked fine, however I noticed that the speed for downloading is now at 90Mbps when connected to Ethernet and 475Mps when connected to Wi-Fi. I tried a re-boot, a new cable and also plugging into a different port and still. have the same speed afterward. I wouldn't mind so much, but I have a switch connected and don't want to see the devices plugged in there to suffer the speed slow-down. Is there anything I can try?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wi-Fi faster than ethernet
Are you connecting through the switch with what device you're testing on?
Have you tried testing a different device connected directly to the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the great suggestion, I tried once again with the following devices:
- Original test - M1 Mac mini / 90/24 connected directly via 2 foot cable to CBR40. (475 via Wi-Fi)
- 2017 15" Macbook - I had to use a USB-C dongle with an ethernet port 60/24 (165 via Wi-Fi)
- iPad Pro - using the same dongle 95/24 (475 via Wi-Fi)
- LG TV connected to a switch (25' ethernet cable run from the switch to the router) 52/22, (50 via Wi-Fi, same room as router)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried swapping around the ports on the cbr40?
What speeds do the satellites get?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't have any satellites, but I did try testing from different ports, the speed was very much the same via different devices. It's interesting that it caps out around the 90 range.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What do you see under the statistics page?
How do I display Internet port statistics on my Nighthawk router? | Answer | NETGEAR Support
- Mark as New
- Bookmark
- Subscribe
- Permalink
Show Statistics |
System Up Time 20:09:57 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
what lan port are you plugged into?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi there, I went to look in the settings, and found this but the field is blank. I've been using Wi-Fi since, but when connected via cable to the CBR40 I used the first of the four ports. (Though I tested on others.) I hope this info helps, not sure where else to look.
Hardware Version | CBR40 |
Orbi Firmware Version | V2.5.0.24_1.0.8 |
CM Firmware Version | V1.01.06 |
CM Serial Number | 5AK2917FA171F |
CM Certificate | Installed |
CM MAC Address | 10:0C:6B:6E:AC:60 |
LAN Port | |
MAC Address | 10:0C:6B:6E:AC:66 |
IP Address | 192.168.1.1 |
DHCP | On |
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do the wan statistics page when a device is plugged into the port
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here's the WAN info from the statistics:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Get the whole wan/lan. Trying to find out what the lan is showing up connected at while a device is plugged in.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for being so patient, this is all new to me!
- Mark as New
- Bookmark
- Subscribe
- Permalink
What ever is pluged into LAN port 1 is only connecting at 100Mpbs and not at 1000Mpbs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
try replacing the cable with at least a cat 6 cable. And try it on different ports to see if its related to the port.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your help, I checked that I'm using a CAT6 cable and also tried different ports. Still the same.
- Mark as New
- Bookmark
- Subscribe
- Permalink
when you switch ports, does the other port switch to 100mbps connection?
do any devices connect at gigabit speeds under the statistics page?
