GarrettB
Jan 30, 2018Tutor
WiFi Speed Slow when connected to Router
Hey everyone. So I'm running the latest firmware as pushed by Netgear. When a Wireless device gets connected to the RBR (Router) I am seeing a 45 mb download speed but the device is using AC and shows it's connected to the router at around 780MB. When the same device is using the Sattelite, it gets a download speed of 220MB (I have a 300 MB pipe). Am I missing something? If anything I would have assumed a wireless connection to the router would have been faster than to the sattelite. Are there any settings I should look at?
Sort By
- GarrettBTutorBump
- budyLuminary
Since I am running my RBK in AP mode, I can only state, that I am not seeing any differences in regards of internet speeds, when being connected to either router or satellite. The satellite, however, is connected via a wired backaul, so I wouldn't expect any differences in DL speeds in the first place and I never camne across any setting, that rings a bell regarding this particular problem.
- rmadilaoGuide
I have a similar problem as you, but in an opposite way. My problem is slow speed with satellite isntead of the router. And it makes no difference if you are using wired or wireless backhaul as the backhaul isn't the problem in my case. It's the fronthaul connection to my mobile device that's being throttled.
Since I"m having issues with Orbi Pro, I posted mine in that section:
- GarrettBTutor
