- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wired Satellite Dropping Wired Connections
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have 2 Orbi Satellites Wired Directly to the Orbi Router. (Star Configuration)
I have a couple of computers wired into one of the Satellites.
Every 15-20 minutes, those computers lose their connection to the router.
I am no longer able to ping 192.168.1.1, until something resolves itself and it comes back.
I have no idea how to debug this. If I plug the wire going to the Satellite directly into one of the computers, I do not have this issue.
Any help would be greatly appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wired Satellite Dropping Wired Connections
What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy...
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Cable modem is a Arris Surfboard SB8200
There is no switch, the satelite wire runs through the wall into the basement and connects directly to the router.
3000 square foot house. The satellites are wire backhauled, not wirelessly connected.
This really isn't a wireless issue. The issue I'm having is with the wired computers.
Router -> Satellite -> Computer 1
-> Computer 2
All those connections are wired. If I take out the the satellite and connect directly to either computer, the issue of the computer losing connections goes away. If I put the satellite there, both computers lose the ability to ping the router every 15-20 minutes, but then it comes back after a couple of minutes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@lokimon wrote:Every 15-20 minutes, those computers lose their connection to the router.
Are you running some sort of "Ping Plotter" program, or have a Command window open with a ping command running constantly?
Or, do you notice a "problem", then open a Command window and attempt to ping?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What Catagory is the cabling between the router and RBS?
@lokimon wrote:I have 2 Orbi Satellites Wired Directly to the Orbi Router. (Star Configuration)
- Mark as New
- Bookmark
- Subscribe
- Permalink
ping -t 192.168.1.1
And watching the output. I will get lost packets every 15-20 minutes for a minute or so, before it comes back.
This does not occur when I take the satellite out of chain and connect directly to over if the computers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would make a back up configuration to file.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have found a coorelation between the satellite losing its route to the router and one of the computers that is plugged into the router connecting to the work VPN. I'm not sure why that should happen or what to do about it. I don't think this is something that has been happening since I got this system.
When I connect to VPN on one of the computers that is connected to the satellite via wire, the satellite (connected via wired backhaul to the router) has intermittent issues connecting to the router (192.168.1.1).
Any ideas?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No switches in between the RBR and RBS?
What happens if you wired behind the other RBS, does the problem follow? I presume you dont' see this if your wired directly behind the RBR?
