Orbi WiFi 7 RBE973
Reply
after update of firmware
wisetulip
Tutor
I updated my firmware on Orbi RBR20 since i am unable to see both icons for router and sattelite on iphone app.  i just see text " Satelite 1" and the modem with waves around it.  the update was done on February 8.  i am not certain if my satellite is working, and if it is the reason I am no longer able to view both icons showing they are connected.  the main and the satellite icones- and only see one now. thank you
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 10
Accepted Solutions
Guru
Re: after update of firmware
Have you powered OFF the ISP Modem and RBR for 30 seconds then back on with the modem first, then the RBR?
How was the system updated? Orbi app or thru the RBRs web page?
Message 2 of 10
All Replies
Guru
Message 2 of 10
vajim
Master
Revert back or spend hours answering questions
Message 3 of 10
wisetulip
Tutor
Your solution worked thank you very much
Message 4 of 10
Guru
Be sure to make a backup configuration to file on the RBR for safe keeping. Saves time if a reset is needed.
Enjoy. Smiley Wink
Message 5 of 10
vajim
Master
Keep an eye on it
good luck
Message 6 of 10
wisetulip
Tutor
"Be sure to make a backup configuration to file on the RBR for safe keeping. Saves time if a reset is needed."
how do I perform above on iphone app? i can only access/view my account on iphone app.
the login.net only brings up the netgear website now.
Message 7 of 10
Guru
You'll need a PC or laptop to connect to the RBR to perform a back up. If you can connect a PC or laptop, you'll find the Backup feature under Advanced Tab/Administration using a web broswer.
Message 8 of 10
vajim
Master
Keep an eye on it
good luck
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 1239 views
  • 4 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
