- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
constant DoS attacxks
- Mark as New
- Bookmark
- Subscribe
- Permalink
so since upgrading to the newest firmware I see constant dos attacks every few minutes and my connection does slow.
Attack: ACK Scan] from source: 34.230.89.123, port 9543, Tuesday, June 19, 2018 22:15:16
[DoS Attack: ACK Scan] from source: 34.230.89.123, port 9543, Tuesday, June 19, 2018 22:13:16
[DoS Attack: ACK Scan] from source: 34.230.89.123, port 9543, Tuesday, June 19, 2018 22:11:16
such as these logs . they continiue to grow larger and speeds get slower all day. Netgear support is no help and the firmware they promised would help manage such issues doesn't seem to be coming . . The QoS feature is broken. How can I fix this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: constant DoS attacxks
That IP address belongs to Amazon:
https://whois.domaintools.com/34.230.89.123
Have you fully rebooted the router and or do a ERASE on it and set it up from scratch?
Whats the Mfr and model # of your ISP modem?
Besure none of your devices are acessing and amazon services. Disconnect ALL devices accept for 1 wired PC and check speeds and connection and the log. Graduate adding one device at a time until you notice something...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have two amazon echoes recently added. I bet thats what it is.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Disable or turn them off and check your stuff.
- Mark as New
- Bookmark
- Subscribe
- Permalink
[DoS Attack: TCP/UDP Chargen] from source: 92.63.193.152, port 48961, Tuesday, June 19, 2018 22:36:19
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can look up these addresses here to see who they belong too:
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think these are false alarms. When I was using Orbi as a router, I saw log entries claiming devices internal to my LAN were committing DOS attacks. Ridiculous.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firewall and logging is doing it's job...just reporting what the router is encountering.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You need to find out if something on your LAN side is accessing those IPs. If your echos are then turn them off and test to see if it still happens or not. If not and you turn them ON again and it does, something in the Amazon services or in the FW needs to be looked at.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello all - I must say I am sick of these DoS attacks from variety of sources.
Have since sent emails (with details) to their "abuse" emails, etc.
Very large number from Amazon Technologies (!) and Lime Light Networks
[DoS Attack: ACK Scan] from source: 52.25.181.51, port 443, Monday, June 25, 2018 20:34:46
[DoS Attack: TCP/UDP Chargen] from source: 209.126.136.5, port 48682, Monday, June 25, 2018 19:56:21
[DoS Attack: RST Scan] from source: 134.19.190.38, port 80, Monday, June 25, 2018 18:43:41
[DoS Attack: SYN/ACK Scan] from source: 31.13.84.1, port 80, Monday, June 25, 2018 18:22:44
[DoS Attack: ACK Scan] from source: 208.111.149.129, port 80, Monday, June 25, 2018 16:59:01
[DoS Attack: ACK Scan] from source: 208.111.155.129, port 80, Monday, June 25, 2018 16:59:01
[DoS Attack: ACK Scan] from source: 208.111.173.167, port 80, Monday, June 25, 2018 16:59:01
[DoS Attack: ACK Scan] from source: 208.111.149.129, port 80, Monday, June 25, 2018 16:57:46
[DoS Attack: ACK Scan] from source: 208.111.155.129, port 80, Monday, June 25, 2018 16:57:46
[DoS Attack: ACK Scan] from source: 208.111.173.167, port 80, Monday, June 25, 2018 16:57:46
[DoS Attack: ACK Scan] from source: 208.111.149.129, port 80, Monday, June 25, 2018 16:56:31
[DoS Attack: ACK Scan] from source: 208.111.155.129, port 80, Monday, June 25, 2018 16:56:31
[DoS Attack: ACK Scan] from source: 208.111.173.167, port 80, Monday, June 25, 2018 16:56:31
[DoS Attack: ACK Scan] from source: 208.111.155.129, port 80, Monday, June 25, 2018 16:55:16
[DoS Attack: ACK Scan] from source: 208.111.149.129, port 80, Monday, June 25, 2018 16:55:16
[DoS Attack: ACK Scan] from source: 208.111.173.167, port 80, Monday, June 25, 2018 16:55:16
[DoS Attack: ACK Scan] from source: 208.111.149.129, port 80, Monday, June 25, 2018 16:54:01
[DoS Attack: ACK Scan] from source: 208.111.155.129, port 80, Monday, June 25, 2018 16:54:01
[DoS Attack: ACK Scan] from source: 208.111.173.167, port 80, Monday, June 25, 2018 16:54:01
[DoS Attack: ACK Scan] from source: 86.105.196.110, port 3306, Monday, June 25, 2018 16:35:04
[DoS Attack: RST Scan] from source: 66.225.197.197, port 80, Monday, June 25, 2018 16:31:51
[DoS Attack: SYN/ACK Scan] from source: 37.242.246.38, port 11211, Monday, June 25, 2018 14:41:27
[DoS Attack: SYN/ACK Scan] from source: 167.114.156.139, port 80, Monday, June 25, 2018 14:14:46
[DoS Attack: SYN/ACK Scan] from source: 167.114.156.139, port 80, Monday, June 25, 2018 13:56:51
[DoS Attack: SYN/ACK Scan] from source: 62.210.92.188, port 80, Monday, June 25, 2018 13:55:23
[DoS Attack: SYN/ACK Scan] from source: 167.114.156.139, port 80, Monday, June 25, 2018 13:44:59
[DoS Attack: SYN/ACK Scan] from source: 62.210.92.188, port 80, Monday, June 25, 2018 13:44:17
[DoS Attack: SYN/ACK Scan] from source: 167.114.156.139, port 80, Monday, June 25, 2018 13:38:43
[DoS Attack: ACK Scan] from source: 157.240.22.39, port 443, Monday, June 25, 2018 13:18:06
[DoS Attack: RST Scan] from source: 72.167.18.237, port 80, Monday, June 25, 2018 13:16:42
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
hmmm....remembered that I had an "old" AWS Linux instance running.
10 minutes ago, I shut it down.
No more DoS attacks - from any source.
If I filter just for DoS, Logs are Empty now!
Whee!
- Mark as New
- Bookmark
- Subscribe
- Permalink
