Orbi WiFi 7 RBE973
Reply
hp 8600 and orbi ac3000
mastpach
Follower
Hello, i can not connect my printer wirelessly. In fact, the printer doesn't even see the correct wifi. It worked fine before we connected the orbi, which  worked fine up until now.
Thanks for your input.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 3
Guru
Re: hp 8600 and orbi ac3000
Make sure the printers FW is up to date.
Please contact the Mfr for help and support information regarding there product.
Message 2 of 3
CrimpOn
Guru
Does the Orbi have exactly the same WiFi name (SSID) and password as the previous WiFi?
Sometimes my computer gets "confused" if a printer changes IP address, which can happen if the new WiFi network does not reserve the same IP address for the printer as the old one did.
Does this process not work?
https://support.hp.com/us-en/printer-setup/hp-officejet-pro-8600-plus-e-all-in-one-printer-series-n9...
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 522 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
