Orbi WiFi 7 RBE973
Reply
netgear RBK23
rvds61
Follower
netgear RBK23
one of my satellite orbi's turns now and then purple, than red, after that
it turns blue agian. This is very disturbing because it is situated in my bedroom.
What could be the problem??
Message 1 of 3
Guru
Re: netgear RBK23
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Try enabling WMM, Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 2 of 3
Guru
Re: netgear RBK23
Any progress on this?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 653 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
