Orbi WiFi 7 RBE973
Reply
orbilogin.net
Lesmor
orbilogin.net
when viewing my devices using orbilogin.net the page seems to refresh every 3 seconds is this normal?
If so why is there also a refresh button?
Model: CBR40|Orbi AC2200 Tri-band WiFi Cable Modem Router
Message 1 of 12
Accepted Solutions
Lesmor
Re: orbilogin.net
I have contacted another Orbi RBK30 owner who has confirmed that he is seeing the same behaviour on orbilogin.net " > attached devices
Doing further investigation I found under "Advanced page " > internet port > show statistics that there is indeed a 5 second poll interval
So I am now confident that this is normal behaviour and will close the thread
Message 9 of 12
All Replies
Guru
Re: orbilogin.net
Does this happend with different browsers?
Which Orbi system do you have? RBR##? CBK40?
Message 2 of 12
Lesmor
Re: orbilogin.net
Hi
First time user here
My model number does not seem to be in the list so I used RBR20 to satisfy the website so
I just installed a Orbi RBK30 which has a RBR40 router and a RBW satellite
I get the same result using my Google Crome or Microsoft Edge browser
the "attached devices" page refreshes every 4 seconds
I also tried netspot which shows 4 Netgear connections with the same Network SSI
2 x 2.4 GHz and 2 x 5 GHz and that page also refreshes every 4 seconds as if it is dropping the connection
My phone also shows 2 Networks with the same SSI only one of them (5 GHz) will connect to the Orbi app
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 3 of 12
Guru
Re: orbilogin.net
Might try a factory reset on the RBR and setup from scratch...
Be sure to clear all browser caches, exit the browser then log back in.
What FW version is currently loaded?
Message 4 of 12
Lesmor
Re: orbilogin.net
Firmware is up to date
I was afraid that might be the suggested solution
before I do that can you confirm that the orbilogin.net "attached devices " list should not be refreshing every 4 seconds?
RBS 40 FirmwareV 2.3.1.58
RBW 30 firmwareV 2.3.0.4
Model: RBW30|Orbi AC2200 Tri-band WiFi Add-on Satellite
Message 5 of 12
Guru
Re: orbilogin.net
I don't believe so...
Message 6 of 12
Lesmor
Re: orbilogin.net
Well as suggested I cleared cookies and did a reset and  fresh install of my Orbi RBK30 and the "attached devices page" on orbilogin.net still refreshes every 4-5 seconds as if it is doing a Auto rescan or dropping and reconnecting
I also had poor download results from "Speedtest" far far worse than from my original Technicolur router
I did a Orbi reboot which seems to have fixed it for now
I would really like to know if this "attached devices" 5 second refresh on orbilogin.net is normal
Message 7 of 12
Guru
Re: orbilogin.net
I would make contact with NG support and ask about the refresh behavior. That doesn't seem right.
https://www.netgear.com/mynetgear/registration/login.aspx
@Blanca_O
Message 8 of 12
Lesmor
Re: orbilogin.net
Message 9 of 12
Guru
Re: orbilogin.net
Ok, thanks for letting us know.
Enjoy. Smiley Wink
Message 10 of 12
Lesmor
Re: orbilogin.net
your welcome and thanks very much for your help
Message 11 of 12
Guru
Re: orbilogin.net
Smiley Wink
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 4231 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
