- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
wifi dropping,
- Mark as New
- Bookmark
- Subscribe
- Permalink
wifi dropping,
Hi all
I have read through some of the posts already posted on here to help fix my issues, with no success.
I am sorry if this is duplicated some where............
Here is my situation.......
I have limited network skills.
I have spent hours on trying to fix this problem and will end up selling the kit i have,,,,, so this is the last chance Orbi has.
I would like orbi to work without BT smart hub 2, but that seems a goal even further away................
I had bought the orbi RBR50m in 2017, hoping that it would help my limited broadband and wifi issues,,,,,,, as the speeds were too slow the orbi system did not work...... Now i have great speeds, YAY!! so was happy to get Orbi up and running.
I have BT FTTP, Fibre 100 installed yesterday.,,,
a white box ONT under the stairs, from this is a cat 5 cable going in to the red WAN port on the back of
The BT Smart Hub 2.
a CAT 5 cable from the Ethernet port on the BT Smart Hub 2 into,,,,,
a CAT 6 socket which is hard wired to the office in the middle of the house.
Orbi sits there with a CAT 6 cable plugged into the yellow Internet port on the back of it.
So, basically directly linked to the BT Smart Hub 2.
I have a 24 port netgear switch plugged in to Orbi to feed the rest of the house which is all hard wired with cat 6 cable.
i have rename the ssid from orbi89 to BT Smart Hub 3,
The problems i am experiencing, again,,,, exactly the same as back in November 2017.....
Wifi dropping, randomly, completely even though i am sat in the lounge or in the kitchen,,,, i do not have to be moving about.
The Orbi satellite dropping out completely which is situated upstairs.
I have an app that controlls my outside soffit led downlighters. i can only sync 2 of the 4 controllers.
my phone orbi app does not connect "WiFi Not Detected"
my Ipad does..........
what i have tried.
changing to AP mode on Orbi and turning off Wifi 2.4 and 5on the BT Smart Hub 2.
Following the steps that another person on here suggested
2.4ghz channel 6
5ghz channel 48
beamforming enabled
mimmo enabled
wmm enabled
armor disabled
circle disabled
daisychain disabled
fast roaming disabled
ipv6 disabled CAN NOT do this as in AP mode it will not let you.
20/40 mhz coexistence disabled
short preable enabled
and various random tweaks unsuccessfully and then resetting back to factory settings.......
i would be eternall greatful, of any help to get me to the otherside,,,,, i really want Orbi to work.
thank you in advanced
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: wifi dropping,
Your home hub would be a router here. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would try option #2 first.
I would change out the CAT5 cable for CAT6 cable. I recommend running same CAT level for all cabling.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: wifi dropping,
Hi Furrye38
thank you soooo much for the info, I really appreciate your time in responding.
i have spent at least 5 hours today,what feels like me going round and round in circles and achieving nothing.
i really hope it works as I love the thought of every room having Wi-fi, the ring cameras connecting with good reception etc. And I would like to put an outdoor orbi in the garden.
I will pick up some cat 6 network cables tomorrow. I will then go for option 2 as you have recommended..
BTW....
I have just got my hands on a TP-link ac1200 modem router, model number. Archer VR400,,,,,, would this be better to use instead of the Bt smart hub 2 or does it not matter about what the orbi is 'plugged" into ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: wifi dropping,
EIther model will work. However since these modems have a built in router already, these either need to be bridge fully do the Orbi router is the only router online, or try option #2 with the modem and Orbi router, or you'll need to configure AP Mode in option #3.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
